snapped an 8rib
Old Jun 5, 2005 | 03:32 PM
Lisa33's Avatar
snapped an 8rib
At the annual swedish camaro club racing event it broke after 50 foot http://home.koping.net/u3243a/tillfalliga/belt.jpg it also smashed reducer to the heater core so it was no more racing for me
guess i have a total of 300miles on that belt (no slipping) have done a little racing an tuning, guess it should be equal to 15-20 1/4 runs...
should i expect this to happend again or is it just bad luck?
edit: 7,65 /4,13" pulley combo on an F1 13-14 psi on oure 383LT1,ported TFS heads, bauer racing custom cam (32x/33x), FMIC, water/ethanol inj..........
ake
Old Jun 5, 2005 | 06:26 PM
Eric G's Avatar
Re: snapped an 8rib
Bad luck. SC belts are supposed to last a long time. Alot of times they dont tho.
Use gatorback belts
Old Jun 5, 2005 | 09:23 PM
markinkc69z's Avatar
Re: snapped an 8rib
You might consider higher octane fuel or a more conservative ignition tuneup. Detonation kills SC belts.
Old Jun 5, 2005 | 09:43 PM
StripedFomula's Avatar
Re: snapped an 8rib
can you elaborate on that more? how does that kill belts?
Old Jun 5, 2005 | 10:02 PM
Re: snapped an 8rib
Because the crank is no longer rotating smoothly in the direction of normal rotation. It really shows up with a cogged belt. People who have had detonation problems killed belts until they got the tuneup nailed. This continues to be an issue. An F1 is a good size blower and it appears to be a new installation. My money is on the tuneup.
Old Jun 6, 2005 | 02:20 AM
Lisa33's Avatar
Re: snapped an 8rib
dont think its the tuning, have 25-24 degrees from 4500-6500, runing 93oct, 8.5 comp, FMIC (24x12x4 core), water/alky, 11.8 A/F, 2step colder plugs,13-14psi boost.
havent seen any knock counts on the scanner at WOT.
have tried it widhout the water/alcy and thats no problem either...
But i have hit the revlimiter a few times so the belt could have been damege then maybe
Havent tought about detonation should be a problem for the belt, have seen a cog equipped car that used 1 belt for every 1/4 pass, and they have had a lot of tuning problems... so i guess that could be the problem...
about gatorbacks, i cant find them here in sweden, can you tell me were in usa i can order them ???
Old Jun 6, 2005 | 07:21 AM
1st and goal's Avatar
Re: snapped an 8rib
That sounds like your problem.
As far as gatorback belts, try www.beltsforanything.com
Good luck,
Marc
Old Jun 6, 2005 | 10:18 AM
Lisa33's Avatar
Re: snapped an 8rib
thanks.
PopoFormula
Oct 12, 2015 04:19 PM
Aaront810
Sep 11, 2015 11:24 AM
sup_sales
Jun 25, 2015 11:10 AM
Robbie
Feb 20, 2003 08:55 PM
