Slight issue--trick flow elbow
Old Oct 12, 2008 | 11:03 AM
The SRZ's Avatar
Exclamation Slight issue--trick flow elbow
As of late the trick flow elbow is blowing off the tb @ 3psi. Normally I could lay down 12psi no problem but now--nope. Trick flow provided some chintsy clamps and the AS&M tb doesn't have a lip on it like the BBK's do. So do you think it's just the cheap clamps or is it a bigger issue? Can't find t-bolt clamps local and I'm not a fan of worm clamps either. The trickflow coupler too is garbage IMO so what size is the coupler we use on 58mm tb's? 3, 3.5"?
Tuning was for this week along w/ finally getting up in the 20+psi range.
Hopefully this is the problem but just wanted to see if others may have experienced this. Thanks.
Silas,
Old Oct 12, 2008 | 11:39 AM
Roadie's Avatar
I used a 4" straight silicone coupler (trimmed to length) and 2 t-bolt clamps to hold mine together. My TB has no lip either and it held 18psi for quite some time before I had exploded an opti rotor and pulled the car back apart.
glenb1991's Avatar
if your talking about the hole for the elbows to connect to the tb its a lil bigger than 4" i got a 4" to 3" reducer and hooked it up there, took some struggle, but got it on nice and tight. hope this helps
Old Oct 12, 2008 | 03:21 PM
97WS6Pilot's Avatar
Its a 4" hose. I used gates white stripe reinforced hose and worm clamps. The gates hose has good properties as far as sticking to the metal on the throttle body. Its similar to water hoses. Even after the clamp is removed it sticks to the metal.
Old Oct 12, 2008 | 08:19 PM
Funkybird's Avatar
I have t bolts and they hold on with my maxed f1a at 19psi. I'm very interested in hearing your results
Old Oct 12, 2008 | 10:37 PM
The SRZ's Avatar
Thanks guys, this gives me hope. I'm off to find a suitable replacement tomorrow if anything is open around here.
magman
Apr 15, 2016 03:08 AM
football4life
Oct 4, 2015 07:48 AM
jayblev95
Sep 26, 2015 09:44 PM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
