Severe Backfire due to Methanol???
Old Aug 7, 2005 | 11:27 AM
  #16
markinkc69z's Avatar
Re: Severe Backfire due to Methanol???
Were you running the same boost on the dyno when you think the valves floated? Remember that what ever boost you have is multiplied by the area of the intake valve which reduces seated spring pressure by that amount. So with 19 psi you have reduced your base pressure roughly 57 psi. Try running at the lower boost setting and activating the methanol. That will help isolate whether it is the methanol system itself or the higher boost.
Old Aug 7, 2005 | 11:42 AM
  #17
engineermike's Avatar
Yes, I'm running 18 - 19 psi on the street and the dyno.
I started out thinking that the Methanol could be the problem, but don't believe that anymore. Though, it may be increasing the severity of the explosion. . .
I'm running 145 lb seat pressure, which to me, seems like about the most you want on a hydraulic roller. I've been considering installing a cam with slower ramps, though.
Mike
Old Aug 7, 2005 | 04:08 PM
  #18
radik's Avatar
Sorry but from a noobs point of view thats pretty cool.. hah all your hoses?, man i guess your running sd since my car dies when i blow off an intake hose.
Good luck and a small bump for you.
Old Apr 3, 2006 | 12:32 PM
  #19
blown383's Avatar
Did you ever figure out that was wrong with your car?
-B
Old Apr 3, 2006 | 02:09 PM
  #20
Bad ignition coil. I installed a new one and the problem totally went away. Methanol makes any minor backfire much more severe.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
tommalcolm
Sep 11, 2015 03:39 PM
