SD concepts
Re: SD concepts
Originally Posted by Sean94Z
I have one, but the car isn't running yet.. It's physically on the car, looks like a great piece.. Just haven't had a chance to do full testing..
--Sean
--Sean
Do you have any pictures of it?
Thank You
Re: SD concepts
Yea, I have some pictures at home, I can e-mail them to you when I get there if you want.
Basically, you send SD concepts your bracket and tensioner and they replace the tensioner with (what appaers to be a ford truck tensioner) and add some supports to the current bracket.. It's a nice setup and is spring loaded unlike the current ATI setup.
They also take all your aluminum stand-offs and grind them down to the same size and include shims to make sure everything lines up when you are finished installing it.
--Sean
--Sean
Re: SD concepts
Looks like yours is working quite well Marc
I'm just trying to figure out if i need ATI's tensioner bracket. When i purchased my D-1 setup it came with the main supercharger bracket and spacers. But it did not have the tensioner or tensioner bracket.
Does the SD setup use the ATI tensioner bracket?
Re: SD concepts
Ok, I'm confused here. My kit has the tensioner on the main bracket itself, and it's a spring loaded tensioner.
Can anyone send me pics of the SD bracket to ponyhntr@hotmail.com?? Thanks!
Re: SD concepts
--Sean
Re: SD concepts
My understanding is that the D1SC bracket is different than the D1 bracket, maybe the confusion is there? I will e-mail pics of everything I have when I get home later..
--Sean
--Sean
Re: SD concepts
Awesome! Thanks for the pics.
It looks like they modified your ATI tensioner bracket and main bracket?
Did the roller/idler come on the tensioner they put on? Or did they use the one off of your ATI tensioner?
Re: SD concepts
Thanks for the pics, Sean. I get it now. The standard ATI bracket has the tensioner (it's spring loaded too) mounted to it. SD modifies the ATI bracket and makes a seperate bracket that their tensioner goes on.
