S Trim Guys
Old Aug 8, 2005 | 04:29 PM
RICEFEDZ28's Avatar
S Trim Guys
I'm Buying A S Trim For A 96 Z28. I Have A 255 Fuel Pump Do I Need To Have The In Line Pump Too?
Old Aug 8, 2005 | 08:01 PM
engineermike's Avatar
Re: S Trim Guys
No, unless you go over about 500 rwhp.
Old Aug 10, 2005 | 03:06 PM
OBE1 95Z28's Avatar
Re: S Trim Guys
My Walbro 255 lph pump (stock fuel lines) has no trouble supplying my system with 593 rwhp.
Old Aug 10, 2005 | 03:24 PM
Re: S Trim Guys
That's very surprising since my 255 lph wouldn't keep up with 550 rwhp. The fuel pressure was falling off 10 psi by the top of the rpm range. Keep in mind that the fuel pressure should increase pound for pound with boost.
Old Aug 10, 2005 | 04:25 PM
Cody's Avatar
Re: S Trim Guys
really when I had the s-trim on my car said it whoa at a 1000 feet with the stock fuel lines, factory in tank and godzilla in line pumps with 510rwhp
Old Aug 11, 2005 | 12:31 AM
OBE1 95Z28's Avatar
Re: S Trim Guys
I'm running the Walbro 255 lph HD; possibly the HD pump makes a difference? My car was dyno tuned by Jeff Creech on a wideband O2 dyno setup with an AFR at 12.0 and I have a A-pillar mounted fuel pressure gauge that shows no signs of dropping off.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 11:59 AM
maybe2fast
Feb 27, 2015 08:09 AM
edman
Jan 22, 2015 02:45 PM
Red97LT1
Aug 7, 2002 05:45 PM
