Which Radiator?
Old May 24, 2006 | 04:06 PM
snorkelface's Avatar
Question Which Radiator?
I'm going to be upgrading the radiator and going with Evan's NPG as we wrap up my PTK kit turbo motor. It will be running about 700HP to the wheels and will be daily driven. While everything is out, I want to upgrade the radiator. What would be the best model to go with (I have an A4)? Below are the two that I've come up with so far:
http://store.summitracing.com/partde...5&autoview=sku
Are there any others I should consider?
Old May 24, 2006 | 09:26 PM
SMOKNZ's Avatar
Re: Which Radiator?
Check out AFCO radiators, much cheaper. Our radiators are 27 1/2 x 19 inches I believe. There are several GM styles that would work.
http://www.secureperformanceorder.co...ProductID=6423
Old May 24, 2006 | 09:39 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Re: Which Radiator?
Personally, I would recommend the stock radiator/fans and coolant.
That's what I use, and my car stays at 180 whether it's in traffic, or WOT for a mile.
My experience with evans NPG is long warm up times (due to no thermostat), and eventually high coolant temps, which would be okay (as you aren't going to boil the coolant), but it can bring oil temps out of control without a cooler.
Old May 25, 2006 | 07:54 AM
SMOKNZ's Avatar
Re: Which Radiator?
evans NPG?? Why would this radiator have high coolant temps. Several of their styles are 3" thick. I plan on using a radiator of this style with a heat exchanger for the oil. I believe they are in the racing radiator section. I plan on utilizing the stock fans as well, will just have to weld some peices of aluminum angle on to the rad. I can't keep cool when I'm buzzing 3500 rpm on the highway at 75... gotta love the 3 speed!
Old May 25, 2006 | 10:04 AM
97WS6Pilot's Avatar
Re: Which Radiator?
Do you still have AC on your car? Whenever I run my AC at stoplights my temps go up to 210 with a 160 degree thermostat.
Old May 25, 2006 | 01:15 PM
Re: Which Radiator?
I do still have AC, and I also have an auto trans with a huge cooler. I am not comfortable with the temps I was getting with my relatively stock engine, and would really worry with an engine like this in stop-and-go traffic that I have to deal with daily.
I'm banking on the Evans based off of some extensive research of some board members here. I know it will show a higher temp at the gauge because it's pulling more heat, and am ready for that. If I am wrong, at least my very expensive mistake can help deter others later.
Old May 25, 2006 | 01:17 PM
Sparkz28ss's Avatar
Re: Which Radiator?
I went with a griffin...
try and find something else......I would if I could do it over again
Old Jun 3, 2006 | 04:09 PM
slp223's Avatar
Re: Which Radiator?
do any of these have a place for the low coolant sensor?
Old Jun 3, 2006 | 04:12 PM
Question Re: Which Radiator?
Good question. I wonder how hard that would be to adapt.
I was looking at this radiator because of the built in heat exchanger for the oil. Anybody have any opinions on the validity it being better to have the oil and coolant having closer temps to each other?
Old Sep 4, 2006 | 06:06 PM
Re: Which Radiator?
Any thoughts?
Old Sep 8, 2006 | 04:52 PM
mzgp5x's Avatar
Re: Which Radiator?
I went with a "be-cool" from Summit (for an M6 manual). It has all the stock hook-ups (low coolant + oil cooler hook-up). The With good air flow (30+mph), temps are steady @ 170*f. But in stop and go, the temp can climb to 210 in 80*F weather with the ATI-D1 & intercooler. Also I have dual 12" 1200cfm flex-lite fans that run constant. I went with a Summit air-to-air oil cooler (trashed the slp). It dropped temps.
Old Sep 8, 2006 | 05:13 PM
slp223's Avatar
Re: Which Radiator?
210 in 80 degree's kinds of scares me. my stocker does beter then that its the 2 months of 100 temps that i need a solution for.
Old Sep 8, 2006 | 05:26 PM
speed_demon24's Avatar
Re: Which Radiator?
With my heads/cam car and my becool radiator, even in stop and go with the a/c on high in the south florida heat, my coolant temp never goes over 180 (on my scanmaster, not the pos gauge).
Old Sep 9, 2006 | 10:50 PM
Acct 23749's Avatar
Re: Which Radiator?
When i drive my car the temps keep going up. no fast really, but over 30 mins its at 210 around town, thats when i usually call it quits and go back home.
Sucks only being able to drive 30-40 mins at a time.
Now on a freeway its fine, night its better.
But racin, after 2 1 mile laps on a road course the coolant is boiling.
sighhh. The problem needs to be resolved, but friends with be cools and griffin have the same problems.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
