Quick fuel question
Old Jun 8, 2004 | 11:49 AM
RealQuick's Avatar
Quick fuel question
I ahve a low pressure 255lph Walbro intank pump. I plan to run around 600rwhp. If this pump isnt enough, I could add a 255lph inline as well. Will this be an improvement, or will it not really do anything since both pumps are rated the same?
Old Jun 8, 2004 | 11:57 AM
IDOXLR8's Avatar
Re: Quick fuel question
I am assuming you want to run an inline to increase fuel pressure through your lines? You may want to buy this instead of buying an inline pump.
http://www.racetronix.com/Racetronix-F-body_LT1_Pump_Kit.html
Old Jun 8, 2004 | 12:04 PM
RealQuick's Avatar
Re: Re: Quick fuel question
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Well, I have an intank Low Pressure Walbro pump already. Will that support 600rwhp? If not what are my options (cheapest possible)...
Thanks.
Old Jun 8, 2004 | 12:32 PM
TonyJ's Avatar
It should work. You might need a boost-a-pump. Jack at Racetronix has the best answers on this issue, IMO... I'm sure he'll chime in soon.
Old Jun 8, 2004 | 12:35 PM
RealQuick's Avatar
So when you say boost a pump, you mean an inline pump?
Old Jun 8, 2004 | 12:57 PM
TonyJ's Avatar
No, it's a box by MSD that increases voltage to the pump under load to spin it faster and thus increase both volume and pressure. Jack could explain it better, I'm just regurgitating here... I think it's around $300. There is some question whether adding an inline pump helps or hurts the flow. I'd like to hear more discussion on this, but a search would probably turn a lot up.
Old Jun 8, 2004 | 01:13 PM
IDOXLR8's Avatar
Also I believe Kenne Belle offers a boost a pump.
Old Jun 8, 2004 | 01:42 PM
RealQuick's Avatar
Ok guys. Good input. Lets keep this one floating around so others could chime in. Again, thanks for the help.
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
Brady
Jul 29, 2002 10:30 PM
