Question about ABS block...
Old Feb 1, 2008 | 02:01 PM
reamo04's Avatar
okay, looking around, it looks like a lot of people have just done away with ABS?
How do I go about doing that, or can I relocate it somewhere or what?
Old Feb 1, 2008 | 02:52 PM
leadfoot94's Avatar
I extended the lines and moved the ABS module where the filter of CAI kit would go.
Old Feb 1, 2008 | 03:21 PM
reamo04's Avatar
my only problem with that, is that I will be puting my piping through there. I guess I could keep it high enough that I still have room for my IC pipes.....ive just been looking at pictures, and not many people have ABS anymore
Old Feb 1, 2008 | 04:57 PM
leadfoot94's Avatar
I run my IC piping right underneath. I guess retaining ABS is a personal choice. I personally feel more comfortable knowing I have it.
Old Feb 1, 2008 | 09:22 PM
reamo04's Avatar
okay, just kindof hard to tell where it was at as far as height
Old Feb 2, 2008 | 04:30 AM
1982z28with18s's Avatar
Mine is gone, more for a clean look than anything. It cost me a whopping $14 to delete it with new lines/fittings, somewhere around I have all the little baggies with the part numbers. I DID NOT use a proportion valve, people say you can't do this, but I did it along with a few others and have ZERO braking issues, I've came down from 140+ mph fairly quick just fine.
Old Feb 2, 2008 | 07:17 AM
c0rey's Avatar
I deleted mine to. I dont have a paportioning valve either. No brakeing problems at all..
Old Feb 2, 2008 | 11:50 AM
97WS6Pilot's Avatar
I deleted mine too. No proportioning valve. Costed about 3 hours and $20.
Old Feb 2, 2008 | 04:07 PM
reamo04's Avatar
awesome. Can any of you guys post part #s for what I will need? Looks like ABS is going bye-bye.
Old Feb 2, 2008 | 05:26 PM
TW95Z's Avatar
If you have ABS only then it's just a double flare plumbing job with a union and tee from the autoparts store. If you want to put a proportioning valve in the rear line then that's your union in that line.
However, if you also have Traction Control then you also need the throttle cable and cruse control cable from a non-TCS car.
Old Feb 3, 2008 | 12:52 AM
reamo04's Avatar
well, i do not have TC, only cruise.
So, the lines coming from the reseviour, where do I splice those to?
Sorry, I have NEVER done anything like deleting ABS before.
Old Feb 3, 2008 | 08:23 AM
Boosted_Z28's Avatar
The line coming from the larger resevoir is for the front brakes (this is the rear resevoir). Install a tee in this line running the two "outlets" of the tee to the front brake calipers (you can reuse most of the old lines) You must use a double flaring tool when flaring the lines. The other line coming from the front resevoir gets tied into the line that is going to the rear brakes (already has a tee at the rearend).
Old Feb 3, 2008 | 10:37 AM
97WS6Pilot's Avatar
Here is a link to the write up I did. It has pics and a parts list. Some of the guys said they had a hard time flaring the lines but I didn't find it difficult. Don't pay any attention to the Safety ****'s who invaded my thread. "Your going to die if you don't put in a proportioning valve." There are some pretty hard headed internet mechanics.LOL.
https://www.camaroz28.com/forums/sho...ght=abs+delete
Old Feb 3, 2008 | 11:01 AM
There's so much truth to your statement, that it's almost NOT funny
Old Feb 3, 2008 | 11:29 AM
reamo04's Avatar
thank you guys. I got the parts list from 97ws6pilot's thread (found it last night at 1 AMish) and will be doing this tuesday (day off)
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
