pulleys
Old Feb 13, 2005 | 02:51 PM
Schurters LT1's Avatar
pulleys
Is the 6" crank pulley (vortech) good or will there be belt slip with it...looking for some feed back..
Old Feb 13, 2005 | 03:06 PM
CoUnTryMuZiCZ28's Avatar
Re: pulleys
Most of the crank pullies are big enough where they wont slip.. its the blower pullies you should really be worrying about.. they have to go through such a tight turn and they start slipping..
Old Feb 13, 2005 | 07:42 PM
OBE1 95Z28's Avatar
Re: pulleys
Never had a slippage issue with my 6" Vortech pulley. I'm presently running the 7" pulley with the stock 3.3" blower pulley, no slippage issues. You will have an intake temperature issue if you choose to pulley up; I added the Vortech aftercooler.
Old Feb 14, 2005 | 12:31 AM
Re: pulleys
can I ask where you got it??
Old Feb 14, 2005 | 12:59 AM
ss#1230's Avatar
Re: pulleys
you can get em from vortech....
Old Feb 14, 2005 | 01:01 AM
Re: pulleys
I called and the A$$ hole I talked to said that they dont make them anymore that big.. biggest is 6.66
Old Feb 14, 2005 | 01:10 AM
ss#1230's Avatar
Re: pulleys
Hmm, yeah i just looked at the site and it has the 6" and the 6.66". i thought they had 7" too.
what are the boost levels with the 6"crank pulley and the 3.33" SC pulley?
Old Feb 14, 2005 | 01:11 AM
Re: pulleys
No idea.. im running a 6.66 and a 2.65 seeing about 14-15 psi @ 6200
Old Feb 14, 2005 | 01:24 AM
ss#1230's Avatar
Re: pulleys
ive had some problems with my boost causing problems with my MAF and now probably my MAP not reading right.
im wondering if im running more boost than i think. i dont have a gauge. and i thought my kit was the 6psi kit and no one else running 6psi or less has had any problems with their maf or anything.....
have you changed to a 2 bar map sensor running as much boost as you are?
Old Feb 14, 2005 | 01:37 AM
Re: pulleys
No.. actually im on the stock map sensor.. I have been looking into a 3 bar one. What problems with your MAF??
Old Feb 14, 2005 | 06:20 AM
Re: pulleys
Country, where did you get the 2.65 pulley, the smallest vortech sells is 2.75
Old Feb 14, 2005 | 12:24 PM
Re: pulleys
I found this site that sells mustang pullies.. they are the exact one for our cars aswell. Here is the site.. they have 2.55 aswell. http://www.velocitymustangperformanc...s/scpulley.htm ...
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
