procharger vs vortec
Maybe this has been beat to death but someone mentioned in another unrelated thread that I should go for a procharger rather than the vortec V2 I was considering. Why should I go for the procharger? Im not looking for an after cooler at the moment, just some extra HP with a straight forward bolt on, no rough idle, no emissions issues, no loud exhaust, etc....
Thanks,
Paul.
Thanks,
Paul.
Re: procharger vs vortec
For the record this has been beaten to death. Anyway both are good superchargers. I have a V1 S-trim. People with both brands run in the 9's,10's,11's,& 12's. They cost about the same new. I bought my vortech kit and all for $1500.00. That is why I have a vortech. FWIW if I had to pay new price I would own an ATI. I believe each company have advantages. Procharger has more advantages though.
Pros For Vortech:
1. More efficient intercooler in terms of less boost loss and air to water works better.
2. Better Tensioner pulley
Pros for ATI:
1. Able to you a larger blower without having to use a cog system and better mounting brackets
2. Self contained oil system.
3. Air to air intercooling is more streetable in terms of maintenance free.
Cons Vortech
1. Weak brackets limiting you to a t-trim with out major mods
2. Oil return line requireing you to drill a hole in your oil pan which sucks if you ever decide to remove blower.
3. More upkeep on intercooler
Cons to ATI:
1. Tensioner setup supposedly isn't as good as Vortech. (supposedly is the key word here as I've never owned one myself so this is heresay)
Thats all I can think of.
Pros For Vortech:
Pros for ATI:
Cons Vortech
Cons to ATI:
Im a big fan of procharger but like The above said, they wont publish there cmpressor maps..why?, I dont know. But There it trie that there head unites usually out perform Votechs. Noew I didnt say ALL the time but from some of the caparisons on stock vehicles Prochargers cars are making more power with there systems. and Plus Im a fan air/air intercooling.
One vote for Procharger. I had the 8psi twin intercooled setup on my car before selling it for a PTK Gen 2 turbo kit. I loved the kit, never had any problems car ran like a raped ape all the time. I have never owned anything Vortech but I have heard equally good things about them. This discussion is like the chevyvsFord. More or less nowadays, its brand prefference. If I hear eqaully good things about two companies but one has better customer service, then thats who gets the $$$. Either way, Procharger or Vortech you will be happy. Or you could do what I did and go turbo. Good luck with your decision. There are PLENTY of knowledgable folks on here to help you out.
Just thought I'd throw in my vote for Vortech. I like the fact that Vortech publishes their compressor maps. Also, there have been 3700 lb cars running 9.9 at 140 mph with the regular ole' S-trim that comes with most kits. As an engineer, I don't like the [ATI] self-contained oiling since there is no way to cool or filter the oil in the unit itself. The Vortech brackets are not weak, as someone else stated, and can be modified slightly to accomodate the YS trim, while a T-trim bolts right in.
You can't compare 2 cars, one with each brand, to see which one is faster or makes more power. Too many variables. I have not seen a valid back-to-back comparison of the head units, which is where a compressor map would come in handy.
Mike
Mike
Well thanks for the input, it sounds like they are pretty much equal and a good choice regardless of the brand. I guess I cant go wrong with either one and it would just come down to price. Ill make sure I buy one that can grow with me because I cant leave well enough alone and will upgrade the engine if it pops in the future and want a supercharger that will still work with a larger engine if I chose to go that route, thanks again.
Paul.
Paul.
