Procharger needs to go now!
2950$ and ill end the auction early!
3250$ and you can have the intercooler and bumper support bracket for it!
Now on ebay!
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7944136876
This is a P-1sc tuner kit that I was putting together. You will get everything seen in the picture:
P-1sc headunit
ATI Bypass valve
Hard blower pipes already fabbed for an OBX FMIC (not included but I can for an additional price)
6-rib Blower crank pulley (optional asp 8-rib crank pulley pictured for another 150$)
Blower bracket and steel idler
All needed Silicone couplers and polished T-bolt clamps (worth over 250$ alone)
ATI Blower inlet hat
ATI Blower oil (not pictured)
Things you will need to purchase to make this work:
Blower pulley of your size choice / belt
OBX FMIC (200-280$ on ebay)
Larger injectors
The tuner kits from ATI sell for 5200-5700$ and are way inferior to the components with this kit.
Here are references for me:
http://www.ls1tech.com/forums/showthread.php?t=228042
http://www.ls1tech.com/forums/showthread.php?t=185782
http://www.ls1tech.com/forums/showthread.php?t=187445
http://www.ls1.com/forums/showthread...eferrerid=2040
http://www.ls1tech.com/forums/showthread.php?t=202905
http://www.ls1tech.com/forums/showthread.php?t=206474
http://www.ls1tech.com/forums/showthread.php?t=243727
Now on ebay!
P-1sc headunit
ATI Bypass valve
Larger injectors
