Procharger install almost done....
Old May 20, 2004 | 05:32 PM
blk95zm6's Avatar
Any words of wisdom or advice? 355 ci, 9:5:1 compression with a 114 LSA blower grind.
This will be the initial startup on a fresh motor too. P600B setup with 3 core....
Just looking for advice from you guy's that have done it before...
Thanks....
Old May 20, 2004 | 09:32 PM
phenyxTA's Avatar
best advice you'll get- BE PATIENT!!! Sometimes it takes time to get an FI car dialed in. I almost sold mine and went back to the bottle several times but it was worth it in the end. Check frequently to make sure the belts not slipping. If it is there'll be black dust on the blower itself. Good luck.
Old May 20, 2004 | 10:31 PM
BLUE95ZZ's Avatar
hope you dont have T/C
What year is your car
Matt
Old May 20, 2004 | 10:37 PM
97WS6SCharged's Avatar
You may consider running the engine for a few hundred miles before installing the blower to help keep metal out of the head unit.
Old May 20, 2004 | 11:22 PM
blk95zm6's Avatar
The procharger is already installed, so i will break in the motor with it on the car.
Fire the car,warm to operating temp and change oil....100 miles, change oil....500 miles...Change oil.....1000 moles , change to a synthetic blend....That's the plan anyway...
I will be patient with my tuning, but it's been 5 months apart!
I'm ready for my toy back...
Old May 21, 2004 | 06:24 AM
IDOXLR8's Avatar
I agree 100% with this comment.
Old May 21, 2004 | 12:08 PM
KS91Z28's Avatar
Just curious, he has a P1SC. How would he get metal into his head unit?
Old May 21, 2004 | 12:39 PM
IDOXLR8's Avatar
Ummm, re-read the original post. He has a P600B.
Old May 21, 2004 | 01:37 PM
KS91Z28's Avatar
Oops. Ok, I guess I accidently looked at somebody else's sig. My bad.
Nov 18, 2023 07:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
