Procharger Case Ventillation (self-contained units)
Old Jun 28, 2013 | 05:01 PM
Alex94TAGT's Avatar
Procharger Case Ventilation (self-contained units)
Didn't see that anyone else has done this, so I thought I'd share a really simple / perhaps dumb idea.
I've always known that these self-contained Procharger units build up some pressure within the case as the supercharger heats up. After changing fluid, I always loosen the dipstick screw once it reaches operating temperature to relieve that pressure, because I suspect it's one of the causes of leaking seals. A little bit of fluid always spurts out when I do.
So, I thought instead of worrying about it, why not just vent the case?
1) What the dipstick looks like (gauged the threads to be 5/16"-18tpi):
2) I found an old brake bleeder screw I had laying around:
3) Used a tap and die set to cut the necessary 5/16"-18tpi threads (Note: this is on a D1sc -- not sure if other head units use a different dipstick thread):
4) Pop a hose on the bleeder screw, and you've got yourself a vent:
5) Installed. (Forgive the dirt -- my BOV is near the ground kicks dirt up everywhere):
Size:  15.2 KBName:  Jva7l3Tm.jpg
Put on a small filter I had laying around:
At any rate, this should help prevent any leaks in the future (though I've had no trouble thus far).
Figure I might be able to use that hose to refill the system as well... or it might sputter and make a mess. Haven't tried that yet.
Old Jun 28, 2013 | 05:56 PM
Kevin Blown 95 TA's Avatar
Re: Procharger Case Ventillation (self-contained units)
I don't have one of those, but agree it is probably a good idea to vent the pressure. Good innovation!
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 10:09 AM
jayblev95
Sep 26, 2015 09:44 PM
95blkss
Sep 22, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
