Powerdyne Superchargers?
http://www.jegs.com//cgi-bin/ncommer...41&prmenbr=361
Ok you know the old saying "what you pay for is what you get"? Well, I was wondering does this apply to Powerdyne super chargers. I have been trying to decide whether to go for nitrous or forced induction in the long run. Well, super chargers like the Vortech models all run easily over 3K. Then I find this Powerdyne model which doesn't even cost $2500. How good are Powerdyne superchargers? Anyone use or have had experience with Powerdyne products? I mean is this thing cheap because in reality it is a cheap product or is it just a good deal?
Re: Powerdyne Superchargers?
Oh, and there customer service sucks.
That's a decent price for a 4.5 lb. PD. Figure on about 50-60 RWHP. The 4.5 kit is fairly safe for a stock motor. Most people want more and quickly upgrade to the 6.5 pulley. That also means you need to add a better fuel pump and an aftermarket ignition (MSD BTM works well). Once you do that you will have spent the difference in price for the Vortech. I really like Powerdyne and have had no major issues with them or their products. If you ever think you'll want more than 6 lb. boost (and you probably will) ... DO NOT GO WITH PD ... it can't be upgraded at this time.
Later ... Larry S.
Later ... Larry S.
ok i dont meen to hijack your thread but i have a quick question about pd sc...ok i plan on buyinhg the pd 4.5 too because i dont want alot off boost...but will i have to worry about a rebuild even thoe i baby the car i dont really drive it to hard....
As noted above ... you always have to consider that a SC can hurt a motor. Adding cylinder pressure has its affects. And with a poor tune the motor can be toast in a heartbeat. Things are generally safer with heads and cam. The SC is usually looked at as a quick way for power without tearing into the motor.
Later .. .Larry S.
Later .. .Larry S.
Superchargers will not destroy your engine. That argument is tired. It's all in the tuning. It also isn't a quick way to make power without tearing into the engine - it is my preferred way.
An LS1 won't even flinch at 4.5 pounds of boost. They will run 8 pounds all day long if you spend the money to get it tuned right.
Miek M
Miek M
Miek M
Miek M
Anytime you make the engine work harder you will wear components quicker.
I forgot to mention that I did agree on that one point - a supercharger is not going to make your engine last longer. Adding any substantial amount of power will shorten its life somewhat. A bad tune will shorten it almost instantly. Beating the hell out of the car all the time will also do so.
With any major power adder, a bit of moderation is a good thing to be blessed with. I was just resisting the notion that you WILL have problems with superchargers. It isn't that cut and dry.
Mike M
Mike M
Made 340rwhp/372rwtq with a 4.5psi Powerdyne, DIY CAI, Hooker shorties, and a cutout. The temp needle was at 210* and the ambient air was 105*.
Your knock sensor becomes very important once you install any kind of blower. Mine stopped reading knock and my motor went south. I would replace your KS when you put the blower on.
Mike M
Mike M
ok so it would be best to dyno tune your car and is ok to use a lt4 knock mod??and what kinda fuel mods should i do with a 4.5 boost??thanks for all the info guys ..im starting to understand all the things you need to do for fi....thanks again guys
Powerdyne
my car runs fine, 355 LT4 (real LT4, not just the top end conversion). I have bigger injectors and in-line fuel pump which came with my original blower, Vortech. I pulled my Vortech and switched to the Powerdyne because it has a cooler air charge (no hot oil line), no worry about contaminated oil if it fails, and is so much more stealthy. Its much lighter too.
95 Camaro Ultra Z - Supercharged LT4
96 Impala SS - Turbocharged/Intercooled & LT4'd
