Postive Displacement Superchargers
Old Dec 12, 2006 | 07:48 PM
JakeRobb's Avatar
Super Moderator
Recently I've seen several people claim that positive displacement superchargers "in effect" add to the engine's actual displacement.
This claim seems absurd to me, so I did a little bit of reading:
http://en.wikipedia.org/wiki/Supercharger
From what I can tell, they do nothing of the sort, and this claim is ridiculous. Displacement on an Otto-cycle engine is (1/2 * bore)^2*pi*stroke*#cylinders, and it will always be, regardless of the type of induction.
I can see a twinkle of actual logic behind the claim, however. A positive displacement 8-71 blower delivers 71 cubic inches of air into each of eight cylinders at every intake stroke, so it would seem like you could add 8*71ci to your engine's displacement and claim that the supercharger makes the smaller engine make the power of the theoretical larger engine, since it's combusting the same amount of air and a similar amount of fuel.
That might be reasonable as an approximation, but it just doesn't make sense in a technical discussion (which is where I always see it used). There are so many other factors involved than the volume of air... this just seems nuts to me.
Am I missing something?
Old Dec 12, 2006 | 08:01 PM
jerminator96's Avatar
Not really. It doesn't actually make the displacement any larger, but it does make the motor act like it has more displacement. The same can be said for all forms of forced induction. I think the difference is in how "directly" the positive displacement blowers feed the air in. It's almost making boost at idle.
I'd call it more of an expression that has been "blown" out of proportion
(shameless pun, I know)
Old Dec 12, 2006 | 08:14 PM
JakeRobb's Avatar
Super Moderator
Yeah, exactly. There's nothing special about positive displacement superchargers in this regard.
Old Dec 12, 2006 | 08:40 PM
slowdrive's Avatar
Just a couple of things....the displacement of a 8-71 is 430 CI per revolution but you would need a 1:1 drive ratio to obtain that....here is a quote that covers the application I think it is easy to see how people would draw the conclusion of added displacement:
"With a supercharger, the amount of air and fuel that can be
packed into the cylinders greatly exceeds the 100% volumetric
efficiency of a highly refined unblown engine. Since the
air is now being forced into the engine, you can put a substantially
denser fuel/air charge into the cylinders. On most
street type blown applications running 6 to 7 pounds of
boost, approximately 40 to 50% more fuel and air can be
packed into the cylinders than in a comparable unblown
engine. The reason that larger displacement engines make
more power and torque than smaller ones is that more fuel
and air are available for combustion. As a result of super-
charging, a small displacement supercharged engine can
produce similar horsepower and torque to a naturally aspirated
larger displacement engine."
Old Dec 12, 2006 | 10:12 PM
Originally Posted by mgray
Excuse me if you already now all of this:
As mentioned, volumetric efficiency is increased because the mass of air filling the cylinder if increased, in comparison to the naturally aspirated engine's volumetric efficiency at the given RPM and atmospheric pressure (a specific mass). At 100% VE, the air pressure of the cylinder equalizes with atmospheric pressure. A VE higher than this indicates a relative, positive pressure differential between the cylinder and atmosphere. In effect, this increases the displacement of the engine because the only concern with displacement is to compare the mass of air possible at a given pressure. If we could use any pressure we wanted (so as to attain any mass we wanted), this would be of no concern. Obviously, there are many reasons we do not use high pressure, miniature V8s.
Though, positive displacement blowers do have a significant advantage. The volume of air (trapped between the corresponding rotors) is mostly constant. By increasing the rate of compression and exhaustion of the blower, the flow changes. Because the change in flow is accomplished with a rate, a measure of change (in this case cycle) per time, the output is near linear. Equally so is the internal combustion engine, for most parts. And, the result is evident in boost at the blip of the pedal.
Well stated.
Old Dec 13, 2006 | 09:30 AM
JakeRobb's Avatar
Super Moderator
mgray, if I understand your post correctly, you're saying that positive displacement superchargers push a constant (or approximately constant) amount of air into each cylinder at every intake stroke. This much I knew from the reading I did yesterday.
But you also seem to be saying that this gives them an inherent advantage over dynamic compression superchargers.
I'm not sure I follow that one. Is it because most dynamic compressors don't make boost at idle? And if so, does that mean that the advantage is gone as soon as the revs reach a certain point?
Old Dec 13, 2006 | 12:31 PM
RealQuick's Avatar
I believe that is exactly what he is saying.
Old Dec 13, 2006 | 12:44 PM
slowdrive's Avatar
Some of that advantage comes back at the far end of the RPM range because the dynamic compressors volume will fall off before the full size roots will (assuming the engine can handle the higher RPM's)
The main disadvantage of the roots is the heat factor.
Old Dec 13, 2006 | 01:27 PM
Kraest's Avatar
Retired
Eaton = Heaton.
Nuff said.
Old Dec 13, 2006 | 01:29 PM
2000GTP's Avatar
Originally Posted by Kraest
Eaton = Heaton.
Nuff said.
Couldn't agree more.
Old Dec 14, 2006 | 02:25 PM
JakeRobb's Avatar
Super Moderator
Okay, so in the end, a positive displacement supercharger is constantly maintaining the same manifold air pressure, regardless of RPM, whereas a dynamic compressor (super or turbo) builds up as RPMs rise, and then if the RPMs rise enough, it falls off again at the top.
Right?
Old Dec 15, 2006 | 07:47 AM
86 IROC's Avatar
Great info thus far...
I don't want to hijack or derail this thread, but I was talking to a few people about a similar subject yesterday. Hope everyone won't mind me adding my $0.10 worth
In a nutshell... I see roots blowers w/ a ci or L rating. Like the KB blowers for 03'-04' cobras, they have a 2.2L & 2.4L. They also offer a 1.7L for the 99'+ 2V GT's. I understand that fine... however, what about a centrifugal blower? Or a turbo car? How do I convert boost into displacement?
I grow tired of the, "But I have a smaller motor" ricer excuse. If the blower or turbo added no power, then why have it? We all know they add substantial power to pretty much anything.
I would like to find a forumla, based on compressor size, and pounds of boost used that would show me roughly how much displacemnt it makes a motor "think" it has. In example... Supras w/ a 2JZ 3.0L, 66mm turbo, and 30 psi.
I appreciate any help and insight anyone here can offer.
Old Dec 15, 2006 | 08:11 AM
Well if 14.7 psi makes it into the cylinder you get twice the air as N/A. (14.7psi = 1 atm = 1 bar)
So you could argue that the 1.8L with 1 bar of boost (measured in the cylinder at bdc) acts like a 3.6L. It's not exactly true but a good generalization.
Old Dec 15, 2006 | 08:24 AM
86 IROC's Avatar
Thank you, that is very much what I was looking for.
Old Dec 15, 2006 | 08:33 AM
JakeRobb's Avatar
Super Moderator
Note that boost measured in the cylinder at BDC is not going to be as high as boost measured in the intake manifold (where a MAP sensor is usually located and thus what is indicated on a boost gauge).
So if you want your 1.8L turbo to act like a 3.6L, you'll need to know your volumetric efficiency (VE) and incorporate that into the calculation. It will, of course, still be a generalization.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
