please help oil fittings p600b
Does anyone else who has the procharger p600b have any pics or information on the oil fittings and lines. I have the head unit, with both fittings on it, the oil fitting has the threads on it, and i have the oil line itself, but i do not have any fittings. also, what is the other fitting on the headunit for? i have the line as well i just dont know what it is for. Any pictures or information would greatly help. Thanks alot
Re: please help oil fittings p600b
Okay, I read, re-read, and re-re-read. Which fittings are you trying to identify?
You have a threaded fitting on the blower for the oil feed and a barbed fitting for oil drain back to the pan right?
I have the threaded fitting on the blower for the oil line. But on the actual line itself, i have no fittings. I need one to go into the pan, and i need one to go into the threaded fitting on the blower.
I'm taking a shot at this purely from memory since the car is sleeping in a cold garage and I'm inside where it's warm. The oil supply line has a female compression fitting on the blower end that attatches to the oil mister fitting. The block end has a 1/8" npt male fitting that needs a 1/4" adapter to thread in to a 1/4" npt hole on the block just above the oil filter for the 95-97 model years. On the 93-94 years I believe you need to install a T fitting where the oil pressure sending unit goes(at the rear of the intake valley I think).
The return is just a oil resistant rubber hose that is clamped to the barbed fitting on the blower oil return fitting. If there is only a threaded fitting for the oil return you can purchase a barbed adapter from any hardware store or a retail chain store such as Menards/Home Depot/Lowes. The fitting for the oil pan is a male thread to screw in to the tapped hole you need to put in the side of the pan just above the normal oil level with a barbed end that you slip the rubber hose on to. Hope this has helped and I appologize if I don't have any/all of the sizes correct. Working strictly from memory here.
stockssn2o
May 25, 2015 08:54 AM
Sandersen511
Jan 13, 2015 03:49 PM
