Piston Ring Gap ?
Old Jan 23, 2003 | 01:44 PM
Maldo's Avatar
Piston Ring Gap ?
What do you guys set your piston ring end gap?
I am rebuilding my motor and I am running Speed pro (Part # TRW-L2256F) forged pistons with Speed pro rings (this is the set with the plasma-moly coated top ring. (All are standard bore)
I am running about 6 # of boost.
Old Jan 23, 2003 | 09:44 PM
engineermike's Avatar
If you run .024 - .026, you'll never have a problem with the gap closing up at high temperatures. I've used that gap before without oil consumption issues.
Mike
Old Jan 24, 2003 | 09:05 PM
EDS Z28's Avatar
I set the top to .025" and the 2nd to .020", basically following Speed Pro's recommendations that came with the rings for a supercharged engine. Now lately there is some belief that setting the 2nd ring gap equal with the top ring gap is better. Not sure about that theory. My motor doesn't burn any oil at all with those gaps.
Old Jan 24, 2003 | 10:02 PM
Maldo's Avatar
Thanks guys,
I set my rings at 28 bottom and 24 top .. I think this will be a good setting for my heavy foot and my non intercooled pd set up.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
mmf_1013
Sep 12, 2015 08:56 PM
