Piston Choice Help Low Comp!!!
Old Mar 2, 2008 | 12:05 PM
jammer94's Avatar
whats up guys i needed a little help on piston choice as i am trying to build a low compression .030 over 4 bolt engine i have i am looking to pull 8:5:1 to 9:0 comp how can i go about doing so in building a bottom end to do so some help with piston choices as i am yet to understand.
i will be for sure running a set of 6" eagle forged rods with floating pins what crankshaft and what piston can i use to acheive this i am currently running the block which has been decked not much and the heads have about 20 thousandths milled off of them what can i do to drop my 10 1/4 comp to 8:5:1.
please guys any help would be apprecated.
Old Mar 2, 2008 | 12:50 PM
roguedriver's Avatar
It sounds like your using the stock castings. If thats the case, don't think you can get down to 8.5. Think the best you can do is about 9:1 or just a tad higher with some chamber work and something like a JE extream duty -31cc dish. Your options would increase if you wen't with an aftermarket head.
Ken R.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
