Picture of my dual walbro setup
Re: Picture of my dual walbro setup
Originally Posted by blown383
I was thinking the same thing..... somone correct me if I'm wrong but I'm assuming Lonnie's set up is -
2 - Walbro pumps
1 - Y block of some sorts, barbed fittings
1 - EFI hoses to connect to the Y-block
1 - Dual pump harness, relays, inline fuses, electrical connectors for the fuel pumps
1 - Hobbs switch
Various conectors to alternator and ground.
From the looks of it I can't see how its going to cost $600?
Does anyone here have Lonnie's setup and can comment? His set up requires you to send in the stock bucket so it makes me wonder if he keeps one pump in the bucket and one outside.
-B
2 - Walbro pumps
1 - Hobbs switch
-B
I did the math and this would come in under 300 bucks.
Not sure how the primary and secondary switch would work but it seems like a good idea.
Before this rebuild I was running without the bucket for 4 years no problem... however once I drop the tank again I might just leave one pump in the bucket and one on the outside however Im not sure if there are any drawbacks to that set up.
From what I read if you try to wedge 2 pumps in the stock bucket... both of those pumps are gonna suck any fuel you have in the bucket completely dry anyways.
-B
-B
I already had one walbro and the Relay so that is why my $140 estimate is so low.
MacGyver would be impressed if you only used duct tape and a swiss army knife to construct the dual pump set up.... oh and if you have a candy bar you'd stop a nuclear reactor from melting down too!
-B
-B
Originally Posted by Fastbird93
Have you tested this yet and verified it's operation. Not that I'm doubting you, but for the price vs. the cost of one of Lonnies dual in tank pump setups, I may be willing to give this a shot myself as it doesn't look like it's that difficult of an item to put together.
I will admit it took alot of soldering and shopping but I'm a perfectionist and usually something that takes most people an hour will take me 2 days. Oh well its my hobby.
I know you've already done more than your share of helping us all out but is there anywhere that I can get a wiring schematic on how this should be wired up.
I just paintbrushed this for you guys. If you want a maunual turn on for the second pump, you just need to use a switch to ground between the hobbs and relay.
I added above how you can do a manual turn on. I need a wiring schematic for the stock wiring to do the switch between pumps so I can see how the relay is controlled (ground side or + side switched?). Someone sends me one I would be more than happy to do it
I like the schematic, but the relay. Is that existing or one purchased for the sole purpose of the dual setup? I SUCK with electrical stuff.......
-B
I'm not running boost in my application right now so the hobbs switch isn't going to do me any good but what I could do is set the switch up to work off of my nitrous activation switch so that the pump is turned on when the master arming switch is turned on.
Then it would just be a matter of getting the pump switch over system.
My relay is wired different than what atljar posted. The ignition on source goes to the hobbs switch and the relay is turned on by the positive wire coming from the hobbs switch. Then the relay is grounded to the frame.
Can you draw that atljar?
