People making 550rwhp or more...
Old Jun 1, 2004 | 12:19 PM
  #16
RealQuick's Avatar
Originally posted by stealth2
Race cars and tight budgets are incompatible. Our experience has been to double whatever budget you have created and it might be close.
I am learning the hard way! I just got off the phone with a reputable machine shop and was told i am gonna be in the ball park of 1000-1200 for prepping the block (that includes setting up for 4 bolt splayed caps ~ 350 charge)
Old Jun 1, 2004 | 03:44 PM
  #17
chevyguy3's Avatar
just get the Street Twin, you will regret it later if you dont. also the centerforce DF for the LT1s is junk. i have been through about 5 or 6 different clutch combos on these cars, and on my last 3 6 speed combos have gone with a street twin as well as using them in local cars i work on. only down side to it besides the price is that the ST is real hard on drivetrain and suspension parts if yours arent up to the task.
IMO the 48lb injectors will be a little on the small side unless you are planning on a superfueler or other means of adding additional fuel. i currently have 42lb injectors with a maxxed out superfueler (3-24lb injectors) and the 42s are running 28+ms pulsewidths so its time to step up. i wouldnt run higher fuel pressure to make the injectors act bigger since that will reduce the performance of your fuel pump which is already on the small side (pumps flow less volume at higher pressures)
Old Jun 1, 2004 | 03:51 PM
  #18
stealth2's Avatar
Since your prepping the block, go ahead and have it receiver grooved or o-ring'd, and drilled and tapped for longer and bigger (9/16) heads studs.
Old Jun 1, 2004 | 06:41 PM
  #19
RealQuick's Avatar
I have a vortech fmu. Will that solve the issue of fuel?
Old Jun 1, 2004 | 06:43 PM
  #20
RealQuick's Avatar
The guy at combination motorsports said if i am only run 12-15psi, then the o-rings werent necessary. I believe he said if I were to run 20+psi it might be a good idea...
Old Jun 1, 2004 | 06:47 PM
  #21
blk95zm6's Avatar
I just hope you have bettor luck with th S\C'r than i apparently did jon.....900 miles and half my boost is in the crankcase...
Old Jun 1, 2004 | 07:39 PM
  #22
chevyguy3's Avatar
engineermike, i tried replying to your PM but it said your PM box is full
Old Jun 1, 2004 | 09:30 PM
  #23
sleeperz28's Avatar
Hell I run 25psi and O rings arent necessary.
Since your prepping the block, go ahead and have it receiver grooved or o-ring'd, and drilled and tapped for longer and bigger (9/16) heads studs[/B]
This block will not need it. There are a handful of guys making the power that I'm and I none of us did this. I know two personaly, for that matter.
Old Jun 2, 2004 | 06:44 AM
  #24
RealQuick's Avatar
John, What are you gonna do, you just got it back together!
Old Jun 2, 2004 | 08:03 AM
  #25
stealth2's Avatar
We agree that LT1 heads have greater clamping force than LS1 heads, e.g., more head bolts.
meissen
Jun 1, 2015 07:59 AM
NewsBot
Jan 8, 2015 11:29 PM
NewsBot
Dec 21, 2014 06:55 PM
racer08
Jul 23, 2002 05:43 PM
