pcmforless tune
Old Jan 22, 2005 | 11:23 AM
shox9879's Avatar
Question pcmforless tune
waiting for my chip to come in and was wondering what to expect and if you guys can tell me what to look or listen for things that might cause my motor harm,its a vortech v1 37lb injectors new racetronix fuel pump no fmu
ive never knew anybody with a supercharger just what i read on this site
Old Jan 22, 2005 | 08:38 PM
Live for TAs's Avatar
Post Re: pcmforless tune
My setup:
383
Forged crank
H-beam rods
Forged pistons 9:1
52mm TB
55#/hr high-Z injectors
LTCC ignition
PCM4Less tune
HOT cam
LT4 heads & intake
1.6 roller rockers
Mac mid length headers
I bought the PCM4Less unlimited upgrade when I built my 383/P600B setup, and have always received good service. I removed the blower due to cooling issues. I got 1 SC profile & 2 NA profiles from PCM4Less.
That being said, with both the SC and NA profiles, the engine has a really bad surge around 2K-2500 RPM, and it has started throwing a SES light for the knock sensor (since replaced, light still comes on). I'm currently working on a rear mount turbo after selling the P600B and have found a local shop that can do a dyno tune. I would suggest this route if it is at all possible.
Old Jan 23, 2005 | 12:58 AM
Alvin@pcmforless.com's Avatar
Re: pcmforless tune
Have you talked to bryan about the surge? He will have some advise or a fix for you.
A knock sensor code will have nothing to do with programming. If the sensor is good look for a loud rocker, exhaust hitting the floor, etc. It could be a fried knock sensor wire too, that happens often. Would explain the surge also.
Old Jan 23, 2005 | 06:37 AM
Re: pcmforless tune
Thanks for the info, I've got the TA in the air replacing springs & will check out the wiring. When I first checked the wire (prior to replacing the sensor), the proper voltage was present.
Old Jan 23, 2005 | 10:14 AM
Re: pcmforless tune
make sure you tug on it while reading voltage.. I've seen wires in that heat shielded harness that runs down the passenger fender well burn clean in two.
Old Jan 23, 2005 | 11:29 AM
shox9879's Avatar
Angry Re: pcmforless tune
this sucks people using my thread to chat start your own
Old Jan 23, 2005 | 01:48 PM
Re: pcmforless tune
Sox, This is Alvin
I wrote you a email after you submitted your order and have yet to hear from you. Please check your email and get back with me ASAP.
Old Jan 26, 2005 | 12:05 PM
imnotfast's Avatar
Re: pcmforless tune
Just did a 2001 Trans-Am with a comp cam and ATI D1SC 8+psi twin intercooled and do not have a FMU. The car runs great and have not driveable problems. The service from PCMforless is best. 4 days from when the PCM sent out till back in my hands.
Old Jan 28, 2005 | 07:48 PM
Lightbulb Re: pcmforless tune
A thousand pardons .
Originally Posted by You: your question
...was wondering what to expect and if you guys can tell me what to look or listen for things that might cause my motor harm...
Originally Posted by Me
That being said, with both the SC and NA profiles, the engine has a really bad surge around 2K-2500 RPM, and it has started throwing a SES light for the knock sensor...
...just what i read on this site
I have found that by searching, reading, & posting (in that order ) I can often find the answer to my question. You asked for what to look (for) and I gave you what happened to me. Sorry for the chat, but this does happen from time to time in threads and usually benefits others that may have experienced the same issue, which in turn eliminates the need to start another thread.
EDIT
Thanks for the tip, I checked the wire & sure enough it was fried by a header tube. I cut out the bad part & soldered in another 12" piece & re-routed it. Should fix the problem.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
