paxta-map fueler calibration?
Old Mar 15, 2004 | 01:38 PM
RMC's Avatar
RMC
I need help with paxta-map fueler calibration.
I need to calibrate my unit to read boost correctly and I'm not sure how to do that. Anyone know how?
Old Mar 15, 2004 | 02:35 PM
Roadie's Avatar
you need an accurate vacuum/pressure pump (mighty vac will work, but only comes with a vacuum gauge) and just follow the manual, which is available on the website.
It doesn't take long to do. First, set the zero point to atmosphere, then use the pump to apply pressure and set the min and max screws to the positions you need.
Old Mar 15, 2004 | 03:11 PM
RMC's Avatar
RMC
Where's the website.
Old Mar 15, 2004 | 03:17 PM
96TurboTA's Avatar
http://www.carrollsupercharging.com/...ler/index.html one of these pdfs has the cal procedure.
95Blackhawk
44
Nov 10, 2010 03:11 PM
CRCDUDE
Jun 12, 2003 12:53 PM
97 RedSS
9
May 3, 2003 04:58 PM
Fbody1
Apr 26, 2003 09:59 AM
Kbird
Feb 11, 2003 06:12 AM
