Paging Roadie or 97WS6Pilot
Old May 2, 2007 | 01:45 PM
  #16
Roadie's Avatar
Originally Posted by RealQuick
If you could shoot it over to me as well I'd appreciate it.
Jon
He has the XFI, so the software is different. If you want to view it, you'll have to download the XFI doftware from the FAST website.
Old May 2, 2007 | 01:48 PM
  #17
RealQuick's Avatar
Already did Thanks for the heads up though...
Old May 7, 2007 | 11:49 PM
  #18
Roadie's Avatar
So, I've been away from trying to fix my car for a little while, but got back on it at the end of last week... JC at Delteq and an engineer at FAST both are aware of my problem are are looking into it. Since everything looks good with the cam signal and FAST, we're going to shoot for a fix with the Delteq box first.
JC at Delteq just overnighted me a couple different revs of the Delteq brain box to try out and see if we can find one that works... Talk about great customer service!
I'll know sometime tomorrow evening if this helps.
Old May 8, 2007 | 12:01 AM
  #19
ramermanz28's Avatar
Good to hear Roadie. Hopefully between the few of us who are experimenting with this combination, one of us is bound to figure it out. I'm still waiting on JC to send me my harness that will plug into the FAST harness. Just got my rotating assembly and block back from the machine shop today. Soon as I get my heads from AI, I'll be getting her put back together. See ya, Rob.
Old May 8, 2007 | 01:07 AM
  #20
ZBLKHELLRZR's Avatar
Well JC sent me another brain box too but it didn't work. I just got done ordering a Crane HI-6R, PS92 coil, adapter harness and plug wires. I hope one of you have better luck and figure it out. I've been down 2 yrs now and the patience has run out esp w/ only having one year left on the autobahn. I cracked...sorry fella's. I'm still going to keep the Delteq in the event there is a cure as I really like the damn thing.
RealQuick sorry for not shooting you a datalog.
Old May 8, 2007 | 09:27 AM
  #21
RealQuick's Avatar
No worries.
Old May 8, 2007 | 08:32 PM
  #22
Roadie's Avatar
no luck with the first of the three boxes he sent me... Everything is too hot for me to swap and try again right now.
http://www.lt1.org/turbo/miss1.gif
http://www.lt1.org/turbo/miss2.gif
The above are two different screen shots of the log I took... Right where the verticle line is located is where all hell breaks loose. Roughtly 14psi boost steady from 3700rpm (left of the graphs) through to there on both. Then spark quits. No fire means no more pressure in the exhaust, and in turn, boost drops off dramatically.
The top pink line is the throttle position. You can see I let off long after I lost spark.
I'm stumped and not having a very fuzzy feeling about the other two Delteq boxes, but I'll give them both a try...
Old May 8, 2007 | 08:40 PM
  #23
RealQuick's Avatar
Opti FTW!!
Sucks Jer, good luck on the other 2 boxes.
Old May 8, 2007 | 08:50 PM
  #24
How old is your OPTI Roadie? Have you gutted it, or is it still stock? I'm still a long way from getting mine put back together, so your our only hope right now. I see John gave up and is going back to the OPTI. I cant believe we can get a Delteq to work with a factory PCM, but for over 2K for a FAST setup no one is having any luck. Are you using your stock wiring harness, or FAST harness'? I've totally gutted my stock wiring and am going to run strictly FAST harness'. I'm frustrated for you. Good luck, Rob.
Old May 8, 2007 | 10:11 PM
  #25
Roadie's Avatar
It's a brand new Accel opti. I know the opti is working right because the RPM signal is never getting lost by the FAST box. If it was lost, then I'd replace it.
I'm using the stock wiring harness with a White Racing PCB interface (plug and play module that goes between the FAST box and the stock wiring harness). Everything works flawlessly for cruising around or even running hard, short shifting at 4500...
I'm fairly certain it's not a wiring issue or an opti issue because we'd see erratic problems, not it dying at exactly 4800 rpm time and time again. I've reproduced it at least 60 times so far in trying to diagnose/fix it. I can't believe how much I'm thrashing this shortblock in such a short time. It's holding up good though.
Old May 15, 2007 | 10:07 PM
  #26
Hey Roadie, any luck breaking that 4800 RPM barrier yet? Thanks, Rob.
Old May 16, 2007 | 10:09 AM
  #27
RealQuick's Avatar
Yeah, I got an email from him. One of the delteq boxes removed the 4800rpm limiter.... and made it 4200rpm No luck. He has the 3rd and final box in the car, but its been raining, so no runs yet.
Old May 18, 2007 | 08:05 AM
  #28
LOL. Really that isn't funny. I hope he has better luck w/ the last box! I swear this isn't looking good...at least for now. He's running the bypass harness too, correct?
Old May 18, 2007 | 09:20 AM
  #29
RealQuick's Avatar
He did get a new harness from Delteq to work with the FAST setup... so if thats what you are talking aout then ya.
Old May 18, 2007 | 09:39 AM
  #30
Roadie's Avatar
Yup... Here's a quick blurb I sent to someone else about the bypass harness and what it does. You can easily make your own (and I would have if I had known it was this simple).
The opti puts this signal out somewhere in the 10-11v range. The Delteq box actually processes this signal and generated a 5v signal to send back to the ECU. In the case of a stock PCM, 5v is all that is needed and there's no problem. In the case of the FAST ECU, it wants a 10-12v signal and usually will crank but not start.
You will appear to have spark because the Delteq box puts out it's own spark regardless of being commanded to or not (this is used to find the correct sequence on start-up). If your problem is this low voltage signal, your FAST box will show 0 rpm while cranking. Verify that you have 0 rpm while cranking before you start cutting.
Assuming you're trying to use a stock harness, what you need to do to fix this is to disect the Delteq opti harness and clip the high and low res signal wires that are comig out of the Delteq box and splice them into the high and low res signal wires going into the delteq box. This gives the FAST ECU the opti signals directly and shares them with the Delteq box.
http://www.delteq.com/Rev5c_VC.pdf
Page 18 of the above doc is the wiring schematic. Clip the PUR/WHT and RED/BLK wires. Splice the PUR/WHT wire going back to the wiring harness into the PUR/BLK wire. Splice the RED/BLK wire going back into the wiring harness into the RED/WHT wire. Cap off the PUR/WHT and RED/BLK wires coming from the Delteq box and leave them disconnected. Now you should have an RPM signal while cranking.
I haven't run the last box yet, but I plan to this afternoon... This last one has no label or anything on it... It's not glued/sealed yet and is just zip-tied holding it together. I'm hoping it's a development box that will make things all better. (I gotta be optimistic here!)
