P1sc 8 inch crank 3.4 blower
Old May 20, 2009 | 03:03 PM
97SS0594's Avatar
spinning 6500rpm max. car is built for it, will a 2 bar MAP be ok? car should build 15psi roughly.
Old May 20, 2009 | 10:58 PM
dookie454's Avatar
Yea, it will be fine, you can actually take a 2bar tune up alot higher than 15psi using the PEvsRPM tables like you would with a 1bar tune, but up to 2bar those are 0'd to let the VE tables take charge, after the 2bar MAP shows 100kpa then you can add a little enrichment via RPM if it's needed.
If anybody's using a 2bar LT1 PCM at the 100kpa limit I'd like to see a datamaster log and a .LT1 or .BIN please!!! (Just for fun)
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
