Opinions on blower cam
Old Nov 14, 2003 | 02:51 PM
RealQuick's Avatar
I was looking into the 224/236 114LSA blower cam. I am currently running the XE230/236 .544/.556 114LSA. Will I see a power difference swapping cams? Will my cam make more power? Any suggestions on a custom cam? I run ported LT1 heads that flow 271/187 @ .550". I got the usual bolt-ons (LT's, 52mm TB, blah, blah).
Old Nov 14, 2003 | 05:58 PM
blk95zm6's Avatar
Hey Jon, blk95z from fbody.com here.
This is the cam recommended for my ATI 9 psi setup and LT4 heads by Cam-motion....Grind # X2161-2222-14+4
Dur @ .050 214 intake and 224 exhaust
Lift .531 intake and .540 exhaust
Lobe Seperation 114
Intake Centerline 110
Should work well with your flow numbers, or give them a call....
Old Nov 14, 2003 | 07:22 PM
RealQuick's Avatar
Lobe Seperation 114
Hey bro. You like the cam? Seems a bit small on the duration. How are your torque and hp numbers?
Old Nov 14, 2003 | 07:44 PM
blk95zm6's Avatar
That's the cam i will likely be running.The blower kit will be arriving saturday,and i'm working on putting together a shortblock with dished forgings.I'm looking for 450-500 rwhp...My winter project Jon!
Old Nov 14, 2003 | 08:01 PM
RealQuick's Avatar
Sounds like we're both gonna have fun this winter! Sounds good. Are the lift numbers with 1.5 or 1.6 RR's?
Old Nov 14, 2003 | 08:29 PM
blk95zm6's Avatar
That's a custom grind using a 1.6 rocker. Yeah the duration seems short but i wanted peak power by 6000 rpm....2 bolt with ARP studs, should live a little longer.....
Old Nov 14, 2003 | 09:15 PM
93formula's Avatar
that cam rocks, i had it but sold it, going for a turbo. that cam is highly recommened by many people on this board. you should see a diff with that cam.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
