Opinions on blower cam
I was looking into the 224/236 114LSA blower cam. I am currently running the XE230/236 .544/.556 114LSA. Will I see a power difference swapping cams? Will my cam make more power? Any suggestions on a custom cam? I run ported LT1 heads that flow 271/187 @ .550". I got the usual bolt-ons (LT's, 52mm TB, blah, blah).
Hey Jon, blk95z from fbody.com here.
This is the cam recommended for my ATI 9 psi setup and LT4 heads by Cam-motion....Grind # X2161-2222-14+4
Dur @ .050 214 intake and 224 exhaust
Lift .531 intake and .540 exhaust
Lobe Seperation 114
Intake Centerline 110
Should work well with your flow numbers, or give them a call....
Lobe Seperation 114
Lobe Seperation 114
Lobe Seperation 114
That's the cam i will likely be running.The blower kit will be arriving saturday,and i'm working on putting together a shortblock with dished forgings.I'm looking for 450-500 rwhp...My winter project Jon!
