Oil pan ?'s
Oil pan ?'s
well, since I need to pull my oil pan to tap it, I am looking at getting a new oil pan since mine is kind of beat up.
Now, to go with a canton, etc, do I have to get a new high volume oil pump or anything, or will the stocker be fine?
Then, (yes, the FI related part), for tapping the oil pan, can I tap it on the side instead of the front?
You don't have to get a new pump, but you will probably need a new pick up. Most of the Canton's come with one now but i'm not sure if it'll fit a stock pump.
As for where you tap it, you can pretty much tap it anywhere away from the crank throws. Like, anywhere where a main cap is would be fine.
Marty
Marty
Marty
Marty
Marty, thank you. I was going to go right into the front, but, i had to put a couple 45* brass fittings on to get my stuff to pass my pipes, and then with the two AN fittings, it left like 1/4" of room for the AN line, so, i have to go on the side lol.
FWIW I got the Canton "road race" pan that has the low oil sensor provision - bolted right up no problems. On the passenger side wing of the pan (on the top) it had a threaded opening. I ran my turbo drain there, no problems.
If you're looking to get a new pan and considering the Canton, it would save you that hassle.
You just need to get a Procharger, then all this worring about tapping into your oil pan will be done (unless you are considering the D1 instead of a D1SC)
I would reccomend a high volume oil pump. Not sure if its "required", but it doesn't cost much more than a stock one would, and its a good thing to have.
. I have a high volume pump now, only reason was because I would have had to order a stock volume pump. There's nothing wrong with a stock volume and white spring. I have a high and white spring
Noct
Jul 14, 2015 01:18 AM
