Nitrous intercooler spray
I have a 94 z28 with a STS kit. I'm currently running meth injection. Next summer I plan to run a fmic. I wanted to run both intercooler and meth. Also I was thinking about the nitrous intercooler spray. For a triple cooling effect. Would that be overkill or could I use all 3 sources??.
FMIC for cars under 9#'s of boost should be enough on its own. Most very high boost levels can be kept away from detonation with methanol injection alone. If you are using both (which I am as well) then you will be well covered, and the nitrous will not be needed to cool your IAT's further, assuming you get the appropriate methanol injection nozzle and setup for your specific application.
I use it... but I use co2 as its half the price
....just some dry nozzles on brackets and a cheater noid and a different fitting on the bottle.Only took a few beers to come up with and get it in the car and working.
It works well for me..... it can get a little warm here so I see no harm in dropping the IAT temps
RUENUF
Mar 13, 2016 03:37 PM
