New build plans....
Old Nov 17, 2008 | 10:52 PM
reamo04's Avatar
New build plans....
So, building a new setup. Going for a HIGH hp LT1....
Going to be a
Engine:
383 with
Compustar crank
compustar rods
JE pistons
Comp 224/236 cam
LE3 heads
splayed 4 bolt mains
Victor EFI single plane with 866 performance elbow
as&m monoblade
Turbo setup
Garret GT88 turbo
Tial BOV
not sure on WG, need to be able to run 22ish PSI so not sure what
Custom 1 5/8" headers, 3" crossover
Dumped exhaust right where a factory cat would be with a bullet muffler
PCM:
Megasquirt 2
Fuel System:
96# injectors
twin walbro 255 pumps with KB boost-a-pump
Upgrade fuel lines with AN lines
thats basically it engine wise, going for the 800rwhp mark on lower boost. I know the turbo is capable of over 1000RWHP with an LT1 at around 25psi
Old Nov 18, 2008 | 08:00 AM
jsetzer's Avatar
Looks good, let me know if yhou need help with the megasquirt.
I haven't been around for a while, what happened with your t70 setup?
Old Nov 18, 2008 | 10:22 AM
reamo04's Avatar
Ended up selling the car as a whole with a redone setup using the SSAC "twin turbo" headers. Now I have another LT1 car that is in a little better shape. Unforunately, this one burns oil, so it needs a rebuild anyways, and i need to redo the radiator vertical, move the battery again, get another madman alternator setup, yada yada yada
Old Nov 18, 2008 | 05:21 PM
jay_rich's Avatar
Wow I wanna work were you do....shoulda just kept the "first" car.
Edit...what are your gonna do for a drivetrain?
Jay
Old Nov 18, 2008 | 06:47 PM
reamo04's Avatar
Jay
haha, well, i am a cook actually, but am also in the navy officer program for the bachelor degree completion program. I get a pretty decent check every month
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
