Need help with damper problem.
Old Jul 24, 2005 | 09:32 PM
slimdawson's Avatar
Last night I picked up a vibe and today my blower stopped whining so after looking around, I came to the conclusion that my pulley is spinning on the crank. I assume if the crank had broken, I would have been able to pull it out but I don't know. So I guess that could be the problem too.
But if it is only spinning(it is really wobbly so tightening the bolt won't do it), can I temporarily fix this? I know you will all say, pull the motor and do it right, but I don't have that luxury right now. I was thinking along the lines of that steel epoxy stuff that gets rock hard. Maybe some set screws too.
Any thoughts?
Old Jul 25, 2005 | 03:12 AM
breakmyfootoff's Avatar
Re: Need help with damper problem.
Park it till you can fix it right, if it's as bad as you describe continuing to drive it is only going to make it worse and you run the risk of damaging other parts that may not need to be replace at this point.
Old Jul 25, 2005 | 03:14 PM
slimdawson's Avatar
Thanks for the input.
I took off the hub today and it is wore really bad. I couldn't see the crank but it didn't feel bad. I will inspect it closer tomorrow. I guess I can get another hub and try it to see if it fits tightly. If it does, I should be ok for a little while at least.
Old Jul 26, 2005 | 02:28 PM
slimdawson's Avatar
Oh yeah, if anybody has a balancer hub they can get rid of, please let me know.
Thanks, Mike.
Old Jul 26, 2005 | 02:42 PM
guardrail's Avatar
mine did the same. Get a keyed hub or do two keys. It will continue spinning until you fix it right.
Old Jul 27, 2005 | 05:04 AM
wicked_95z's Avatar
Mike I have one. Do you need the balancer too?
Old Jul 27, 2005 | 08:47 AM
slimdawson's Avatar
Joe, I only need the hub.
How can I use a keyed hub without taking the crank out?
Old Jul 27, 2005 | 11:16 AM
RealQuick's Avatar
The snout of the crank that sticks out of the timing cover has a keyway already. I bought hub that as keyed from Thunderracing (which includes a key). Lay the key on the crank and install the hub...if memory serves me correctly.
Old Jul 27, 2005 | 02:54 PM
slimdawson's Avatar
I did not know the factory cranks were keyed. May have to clean up the keyway.
How much was that hub from Thunderracing?
Old Jul 27, 2005 | 03:53 PM
RealQuick's Avatar
Umm...maybe 129 with a core of 49 when you send it back. I dont quite recall. Give them a ring.
Old Jul 27, 2005 | 06:41 PM
slimdawson's Avatar
Thanks.
Old Jul 27, 2005 | 08:21 PM
Sean94Z's Avatar
Quite a bit of good reading on this subject .. Do yourself a favor and fix it right the first time ...
Check these threads..
http://web.camaross.com/forums/showthread.php?t=94282
and this ..
http://web.camaross.com/forums/showt...threadid=94281
and this ..
http://web.camaross.com/forums/showthread.php?t=178096
and this ..
http://web.camaross.com/forums/showthread.php?t=202609
and this ..
http://web.camaross.com/forums/showthread.php?t=312916
http://web.camaross.com/forums/showthread.php?t=340610
http://web.camaross.com/forums/showthread.php?t=340321
http://web.camaross.com/forums/showthread.php?t=298109
http://web.camaross.com/forums/showthread.php?t=178369
Old Jul 27, 2005 | 09:52 PM
slimdawson's Avatar
Thanks Sean for the links. Right now I am going to at least try another hub so that I can have something to drive while I am collecting parts.
I liked the experience with the blower, but I am planning on going turbo. I don't like the parasitic loss but I can say that my setup never threw a belt or slipped. It will be hard to get rid of it.
Old Jul 28, 2005 | 05:17 AM
wicked_95z's Avatar
MIke you can have the hub. All you have to do is come get it. I live just the other side of Havelock from you. I can box it up and mail it to you if you want to paypal me shipipng
Old Jul 28, 2005 | 09:27 AM
slimdawson's Avatar
Joe, thanks. I am going to the beach Friday so maybe we can arrange a pick up sometime that day. What time frame is good for you?
