Are MSD 50#'s really that bad?
I have 50# Flowtested Injectors from Combination Motorsports and they work well. I believe they are MSD injectors but were flow tested. I heard a lot of guys having funky ideling problems and getting poor gas mileage (like 10MPG on the Highway). I had Bryan at PCMforless personally STREET tune my car and I am getting 14MPG in mixed city driving and about 18MPG on the Highway. And my car idles beautifully, so I am happy. I hear a few guys on here that made it to the mid 500RWHP level with 50#ers and then started running lean.
I currently have header leak which is causing my car to run rich but once I get that fixed and install a new off road Y-pipe, I will have my car Dyno tuned with WideBand 02s. I am shooting for around 450RWHP give or take about 10-15HP on a Daily Driver that sees 600 Miles weekly. Later down the line, that may change
Thanks,
Claude
Thanks,
Claude
My MSD 50s worked great I think the reason you see them for sale is that people outgrow them. That is true in my case but if you are making in the mid to low 500RWHP range then they are great. I happen to have a set for sale if you need some.
Jeff
96 SS BLOWN
96 TA 396 D1
Jeff
96 SS BLOWN
96 TA 396 D1
Mav
Wow this thread is funny. I mean almost all the turbo buicks I know off run 50's and have had zero issues. they're selling in a flash on the TB board. Like hot cakes..gone
I run mine at 70 PSI fuel with duty cycles at 75 percent and get my 3600 lb car to go mid 11's rite under 120 MPH.
Funny how someones junk can be someone elses treasure.
Maybe its the drivers inside the factory PCM that dont work well or??? I use my stock ECM and have never had any failures.
I guess it depends who's burning the chip that matters. And running them past static is a no-no reguardless of injector.
HTH
Julio
HTH
Julio
