massive FP spike....Why?
What would cause a massive spike in FP? We are talking 125+ psi
New Walbro 255 lph, ATi inline pump and an Aeromotive Adj. FP reg.
Spiked to 125+ and blew the Quick connect OFF the fuel filter!
If i pull the fuse for the inline pump, it holds at 40 psi running....
If i just turn the key on, it goes to 40, pump stops and it drops rapidly....If it's running at 40, it will creep to 60...What's left? Bad FP reg? FMU? I changed the wires, plugs and in tank pump to cure "breaking up" under load......and it STILL won't hold rail pressure and "breaks up".....
I'm at the end of my rope.....
anyone?
anyone?
Thanks for the replies guy's...I only running 9 psi...and what's a BAP???
When i got home from work tonight i fired it up on the intank pump only. I then removed the vacuum line from the FP reg. and fuel pressure DID NOT CHANGE
....Huh?....
Looking at the FMU, does anyone know which line runs to the return on the fuel rail?....Center or bottom?
I bought this kit used with lines already on the FMU, both with male fittings and hooked them up accordingly....Male on the end of 1 hose, female on the other, so my install book doesn't tell me which ones which, because they call a female fitting on one, and a male on the other....
I pulled the vacuum line from the FP reg at the manifold and it was dry....Man, this is driving me nuts!.....I'm about ready to throw in the towel....
....Huh?....Looking at the FMU, does anyone know which line runs to the return on the fuel rail?....Center or bottom?
....Huh?....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
