manuel boost controller?
Old Apr 23, 2010 | 05:32 PM
RudeOne73's Avatar
? for ya. If you want to run 6lb of boost on the street and 10lb of boost at the track what size spring do you run in the waste gate?If you have a manuel boost controller can you turn it down to 6 for the street and then just turn it up for the track with a 10lb spring in the wastegate?Confused how the 2 work together?
Old Apr 23, 2010 | 11:35 PM
MikeGyver's Avatar
Old Apr 24, 2010 | 12:00 AM
MikeGyver's Avatar
You can run a 10# spring and use one of those controlled leak manual boost controllers, or u can run a 6# spring and figure out a way to put 4psi of boost to the wastegate's top port.
Old Apr 24, 2010 | 08:12 AM
RudeOne73's Avatar
So i can leave a 10# spring in the wastegate and control the boost with a mechanical boost controller from 6-10?I'm new to turbo's so excuse my ignorance but at 6#'s of boost how does the 10#spring open up on the wastegate?Does the controller leak out the 6#'s?I have a tial wastegate and a turbonetics manual boost controller.How should i set it up because I'm getting ready to put the turbo on and then take it to the chassis dyno before the track?
Old Apr 24, 2010 | 06:18 PM
MikeGyver's Avatar
I think I've got it backwards on the 10# spring.
You can use a 6# spring and a manual controller which bleeds a controlled amount of air. So when your turbo is making 10# of boost, 4# is leaking out of the manual controller and 6# is getting to the wastegate, so as far as it knows it's only making 6psi.
For the other method, you run boost into a regulator and dump 4psi into the top port of the wastegate, this adds to the 6# spring essentially making a 10# spring.
Old Apr 25, 2010 | 11:17 AM
RealQuick's Avatar
The minimum boost you want to run is the spring that goes in the gate. The controller is used to raise the boost over the spring psi.
Old Apr 25, 2010 | 11:47 AM
RudeOne73's Avatar
Smile
thanks that was explained perfectly!!!!!!!!
RUENUF
Mar 13, 2016 03:37 PM
Formula Steve
Sep 19, 2015 08:48 PM
Henson071
Sep 18, 2015 04:01 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
