MAF delete for boost
Old Feb 17, 2010 | 08:16 AM
onefastmx5's Avatar
I've been reading up on those running a 2 bar map with speed density. When I get the supercharger put in, I'm going to try it out. When you delete the MAF, do you just leave it unplugged? Will it throw a SES light? I'm using Tunercat.
Old Feb 17, 2010 | 08:59 AM
97WS6SCharged's Avatar
Not sure how well that will work out in the tuning tables, you'll probably lose resolution with the 2 bar. Anyhow, once the maf is tuned out it's nothing more than a restriction so you may as well remove it.
Old Feb 19, 2010 | 04:29 PM
Kevin Blown 95 TA's Avatar
You'll be in speed density mode, so there's a check box for that in the switches list.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Double aught
Oct 2, 2015 11:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
