LT1 P1SC boost limit?
i just scooped up a 97 SS with a 355 fully forged (GM forged crank eagle rods, wiesco pistons) 8:1 compression and a P1SC at 12psi, whats the max i can take it too and with the 8:1 can i put lets say a 100-150 shot through it and still be safe?
Dude, running FI and Nitrous is ASKING for a blown motor. It's normally pretty difficult to keep one of these things alive when running one or the other. There are too many things that can go wrong. I'm not saying it can't be done, just that the risk level goes up an order of magnitude. Do one thing, and do it well. If you want more power, then bump up the boost a couple psi.
Mike
Mike
agreed. these motors make everything you want with one power adder. By nature they are high compression motors and like to be that way, you can modify anything but theyre really not made for high boost/spray applications.
im not running a stock pistoned motor thogh, the motor is fully forged with splayed caps and is 8:1 our motors by nature are high copmpression because of the piston design and the head design, you change that geometry and you have a low compression motor by nature
97,
Not familiar with ProChargers, but 12psi w/ a P1SC on a built mild/built motor kinda sounds like the blower is close to max. Have you calculated impeller speed to see if you could spin it harder?
-Scott.
-Scott.
