View Poll Results: What type of kit would you be most interested in?
Single T4 turbo kit (T60 thru T76)
30.77%
Twin Turbos (using T60-T76)
15.38%
Single T6 Borg Warner S400
46.15%
Single Race Setup (S76-S91)
7.69%
Voters: 13. You may not vote on this poll
LT1 Boost looking for suggestions
Old Sep 22, 2008 | 01:01 PM
RealQuick's Avatar
What do guys want to see for turbo kits? Obviously the standard T4 T60 - T76 turbos, but what else?
Twin Turbo with T60-T76's??
Single turbo kits that use S400 turbos (since those turbos support 1000hp and only cost $600)????
Single turbo T6 race setups for S series turbos (S76-S91) (up to 1200rwhp)??? You would lose your A/C and need to stand the radiator up vertical as well as run an oil scavenge pump.
What else would you guys like to see?
Old Sep 22, 2008 | 01:38 PM
slomarao's Avatar
twin t66's would be nice.
Old Sep 22, 2008 | 01:42 PM
RealQuick's Avatar
People willing to get rid of their A/C for it?
Old Sep 22, 2008 | 03:08 PM
Sparkz28ss's Avatar
i would like to see a header kit that uses the S400 and keeps the AC with out having to go to a stand up rad
Old Sep 22, 2008 | 03:14 PM
RealQuick's Avatar
This is doable, but you are talking about a low mount (so you'll need an oil scavenge pump for the drain side) and you will need to run the DP on the driver's side... so you are limited to a 3" DP.
Jon
Old Sep 22, 2008 | 03:23 PM
Sparkz28ss's Avatar
Jon
The oil scavenge pump is not that big of an issue....other then it adds something else that could go wrong.
Could you get 3.5" downpipe to fit a S400 setup with the use of a BMR k member?
What size down pipe can be used on your T76 header kit witha BMR k member?
Old Sep 22, 2008 | 03:36 PM
slomarao's Avatar
I would be willing to do anything to keep the AC and have the twins. BMR k member whatever, Just need the both of them.
Old Sep 22, 2008 | 05:28 PM
jsetzer's Avatar
Run the s400 with a big 4-5" cutout before the axle and cut it down to 3" to get past the motor? Not ideal for all people but we are doing a similar setup on an ls1 right now.
What about the new masterpower 76? I'm a huge fan of budget builds. Or would it be a direct swap for the 70? I don't know if the housings are the same.
Old Sep 22, 2008 | 06:42 PM
crazycat's Avatar
How come no one runs dual 3" from the turbo back. Thats how I did mine. 4.5" out of the turbo into dual 3" on each side of the kmember all the way back.
Old Sep 22, 2008 | 07:21 PM
RealQuick's Avatar
I can fit a 3.5" DP with stock k if i plan it right. Does it have to retain A/C?
Old Sep 22, 2008 | 07:23 PM
RealQuick's Avatar
thats a tough one!
Old Sep 22, 2008 | 07:26 PM
RealQuick's Avatar
The best budget turbo is the S400... FI.com sells them for $599 with a t6 housing.
I havent seen the MPT76 yet.
Old Sep 22, 2008 | 07:27 PM
RealQuick's Avatar
Thats a good option.
Old Sep 22, 2008 | 07:29 PM
RealQuick's Avatar
I have actually started building a twin T4 turbo kit (T60-T76)... should support ~1100rwhp... a/c delete though... but radiator stays in stock location
Old Sep 22, 2008 | 09:10 PM
IROCThisZ28ForLife's Avatar
I wanted twins originally but one fat one will do me just right!! A S400 kit would be awesome, I def woulda jumped on one of those for the price they are!!!
