lifting the heads?
Old Jul 7, 2003 | 03:38 PM
SMOKNZ's Avatar
lifting the heads?
2 weeks ago when i was on the dyno when we moved the car off the dyno i had 2 little puddles of coolant and on further investigation it was coming from the head gasket. I have no coolant in the oil, and i am no longer loosing any coolant, and i am not overheating. I haven't been getting on it much either, as i have no place to work on my car right now (building new garage)
Are the head gaskets shot now (again) and if they ar should the heads be milled to prevent this. I didn't mill the heads the last time i blew thehead gasket, but i should have. Let me know what ya think.
Bill
Old Jul 7, 2003 | 05:37 PM
94SLUG's Avatar
I had my heads O-ringed. Sure your not detonating. I would assume if your heads where lifting coolant would make it other places than under the car. Power would drop bigtime, and I would think you could hear the compression seeping out (Being on a dyno). Checking for blown head gaskets is easy. I just dont think your lifting your head, but what do I know . How much Boost?
Its never a bad idea to have the heads re-surfaced after a high temp or high mile motor.
The other Bill
Old Jul 8, 2003 | 06:29 AM
SMOKNZ's Avatar
It was hitting 18 psi. The coolant was seeping from the outside lower edge of the head on the corners, not flowing or spurting or anything. Like i said, i haven't had any problems since. Car runs great. Should i just let it go?
Old Jul 8, 2003 | 06:48 AM
Brady's Avatar
Mar car lifted the heads last year quite often. I had arp bolts and felpro 1074 gaskets. It never blew a gasket or caused any other problems that I could see... I let it go all summer until "winter teardown" where I changed to Cometic gaskets and ARP studs..
..and FWIW, I lifted the head(s?) Sunday, at a minimum.. The car won't run as of now..
Old Jul 8, 2003 | 07:58 AM
Brandy's Avatar
Personally I think you are lucky and should consider the seapage as a warning of worse things to come. My engine blew the fire rings into the cylinders and ended up blowing the lower radiator hose off. Fire rings are hard and dent the heck out of pistons, not to mention what would have happened if I blew the hose off going down the track! I strongly suggest fixing the problem before it causes more damage.
Old Jul 8, 2003 | 08:37 AM
NoSlix's Avatar
94Slug: With a nitrous or supercharged car, if you lifted the heads you would notice a drop in power. But one thing I've noticed with turbo motors is that they'll run the same no matter what. We've blown heag gaskets between cylinders before where the two cylinders showed 60-70 leakdown. The motor made the same power and the car ran the same et. I've got a friend with a 800hp T72 powered 4 cylinder SVO with two of the cylinders showing over 25% leakdown. Still ran a 9.23 at 146mph. A turbo will just keep filling the cylinders as long as it's not compressor limited.
My opinion is that if you lifted the heads once, you'll do it again. You need to find out why it's happeneing.
Old Jul 8, 2003 | 09:38 AM
Pro Stock John's Avatar
What was your A/F ratio on the dyno?
With 18psi I would expect that you would make more power than that, like over 600, maybe 650rwhp?
I have done a lot of research into FI tuning, and I see a lot of fast folks who run in racing series reccomending me that I run 11:1 - 11.5:1 AF on a Dynojet.
Old Jul 8, 2003 | 03:54 PM
SMOKNZ's Avatar
A/F ratio was around 11.5:1 thru the whole rpm band, give or take a few tenths. Yeah I think the power should have been more, but maybe the small crossover and log header are now becoming a big restriction.
Bill
Old Jul 8, 2003 | 05:10 PM
JZ 97 SS 1500's Avatar
I think the problem with lifting the heads is your header. Its creating so much backpressure thats its reverting back into the exhaust runner. Which will create alot of heat and eat up those gaskets fairly quick.
Jose
Old Jul 8, 2003 | 05:27 PM
96TurboTA's Avatar
Post
Jose, if the world broke out into nuclear war, you'd probably blame it on the header.
Old Jul 8, 2003 | 06:05 PM
9 times out of 10 when folks do a post mortem, assuming they did not screw up the initial install, it's detonation. If you burned up the gasket between cylinders that might not show as much but it's going to get worse I would bet.
Here's another huge generalization, but when I looked at turbocharging my car when I would see modest HP @'s coupled with big torque numbers it seemed like that's the result of a restriction.
Old Jul 8, 2003 | 11:18 PM
hehe, nahh, actually Bill has a good setup and his 355 definitely has potential to make alot more power. But when the entire motor is flowing through a 2.5" pipe, it doesn't take rocket science to figure out what his bottleneck is. I think if the log was 3" the car would probably pickup a ton of power
Old Jul 8, 2003 | 11:38 PM
96TurboTA's Avatar
I agree.
Old Jul 9, 2003 | 09:56 AM
Not to start a tangent, but itsn't Intmd8 running thru a small log and crossover? JZ what mph does your car run?
Old Jul 9, 2003 | 10:47 AM
John, actually Intmd8 if I remember correctly is running true headers and they are VERY nicely done. I think they are 1 5/8 primaries with a 2.5" crossover pipe. My car isn't done just yet. I'm waiting on some last detail parts from PTK to get this thing going. I really have no idea how it will run. I will be testing 2 different header setups for PTK, so it will be nice to see what the differences are.
