lets see your turbo supports
Old Feb 22, 2008 | 10:20 PM
reamo04's Avatar
wanting to see some supports for turbos so i can see how i want to support mine
Old Feb 22, 2008 | 10:34 PM
jerminator96's Avatar
What do you mean "supports"?
In all of the setups I have seen the turbo is supported by the manifold/headers.
Old Feb 22, 2008 | 11:50 PM
reamo04's Avatar
well, like a bracket made to support it so the weight isnt on the pipes as much
Old Feb 23, 2008 | 02:49 AM
jammer94's Avatar
when i get mine installed which i had to pre fab they go to the chassis or frame on my b-body and it went with a bolt off the turbo exh. flange to the chassis with a piece of heavy mud flap rubber its hard to explain it, its like a piece of conveyor belt rubber real thick about 2" thick so that it can have some give.will post pics.
but for another type of system i would just find a moutning point on the block where you can screw in a bolt with a metal bracket going to what looks like the weakest point on that side its pretty simple i accomplished this belive it or not using the stock support brackets which come on the b-body lt1's which goto the back of the alt to the manifold and to block.
Old Feb 28, 2008 | 12:50 AM
AdioSS's Avatar
West South Central Moderator
what do people use when the turbo isn't right at the exhaust manifolds/headers? Like in a rear mount application.
Old Feb 28, 2008 | 08:09 AM
jsetzer's Avatar
Rear mounts will either use good hangers on the exhaust or just build a bracket for the turbo.
I am not using one on my front mount, its pretty close the the drivers side log and our little t70 is about half the weight of some of the other turbos.
alliance12364
Sep 23, 2015 12:40 PM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
