Issues with SDCE idler pully
Old Mar 13, 2007 | 08:29 AM
xxsaint69x's Avatar
Well i started to experience problems with torn up belts... I took the idler pulley off and noticed that it has worn out quit bad from the outside (side closest to the bracket). Can someone describe a way that i can check to make sure everything is lined up correctly?
Ill take a pic of the idler here in little bit.
Old Mar 15, 2007 | 10:06 PM
97WS6Pilot's Avatar
This bothers me. I hope mine is not doing the same thing. You could take a straight edge and put it on your crank pulley. Might be tight quarters though.
SpeedJunkee
Jun 6, 2015 04:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Rocko
Jul 31, 2002 05:39 PM
BlowBye
3rd Gen / L98 Engine Tech
24
Jul 22, 2002 07:56 AM
