Interesting turbo headers on Ebay
Old Mar 13, 2006 | 11:15 AM
mn_vette's Avatar
I was just wondering if someone here has used these headers. They seem to be a steal at this price. Just wondering if they will fit and what not.
http://cgi.ebay.com/ebaymotors/SBC-T...QQcmdZViewItem
Old Mar 13, 2006 | 12:05 PM
96TurboTA's Avatar
Re: Interesting turbo headers on Ebay
I saw those over on turbomustangs.com a few months back. I don't know if anyone has tried them in a 4th gen yet.
Old Mar 13, 2006 | 12:50 PM
RealQuick's Avatar
They are too low and come way forward. You'd have to make a custom alt. bracket, and swing the alt up. Also need to ditch the ps pump it looks like.
Old Mar 13, 2006 | 01:56 PM
MonkeyBoneSS's Avatar
Dam if those did work, that would be one sweet set up there! Wish it would
Old Mar 13, 2006 | 02:21 PM
mn_vette's Avatar
You'd have to move things of course, kinda like this one?? We've all seen SleeperZ28's setup at just over 1k rwhp. You'd have to get some T4 flanges instead of the T3's but I'm sure if you talk to the people that are making them it shouldn't be a problem. You'd have to put in some wastegate ports too if you were thinking about that much hp. But even twin t3's will still pull a good 600+hp.
http://www.ls1tech.com/forums/showthread.php?t=385240
Old Mar 14, 2006 | 07:51 AM
akafred's Avatar
they look nice... it would be nice if they made a LH & RH version thou one turbo will be aimed up the other down....
Old Mar 14, 2006 | 08:51 AM
mn_vette's Avatar
They did, If you look at how the header flanges are you'll notice some notches cut out of them on one side. Those are the bottom. One side slopes up slightly the other down slightly so the turbos should end up in the same position if you are using a tangential housing.
Old Mar 14, 2006 | 09:00 AM
akafred's Avatar
i still think they would look better if they made a mirrored lh and rh version
Old Mar 16, 2006 | 10:04 AM
A/G's Avatar
A/G
These were meant to exit forward or rearward?
Old Mar 16, 2006 | 10:09 AM
RealQuick's Avatar
Forward. They are twin turbo headers....the'd run into the firewall if you had them backwards
Old Mar 16, 2006 | 11:17 AM
Roadie's Avatar
tho they'd make great rear-facing headers for a rear-engine drag car.
if they were that easy to fit into a 4th gen, I'd have saved a lot of money. I saw those for sale about a year ago through a shop for $400ish. I think they'd drop right in a 2nd gen.
Old Mar 16, 2006 | 11:23 AM
RealQuick's Avatar
Haha! Yeah 1st and 2nd gen fbodies would be able to use thoug I would think. Its nice to be able to jump in the engine bay when you want to do plug changes!
Old May 24, 2006 | 04:16 PM
blown383's Avatar
Most of the stuff from SSAutochrome is complete junk! Stay away!
-B
Old May 24, 2006 | 05:32 PM
Dennis93TA's Avatar
just my 2 cent but lt1's have d-port exhaust ports.
Old May 25, 2006 | 08:34 AM
RealQuick's Avatar
Doesnt matter if the primary tubes are larger than the D ports on the heads. Now if the primary tubes were smaller and blocked part of the "D" then it would be a problem.
