injectors with FMU
Old Jul 11, 2004 | 09:15 PM
SharpZ28's Avatar
injectors with FMU
I am wondering if stock 22lb injectors will be o.k. while using a Vortech FMU with 8:1 ratio calibration on a 92 Z28 TPI ( Paxton supercharger @ 6lbs boost ) ? Thanks for any advice.
Old Jul 11, 2004 | 09:44 PM
Alvin@pcmforless.com's Avatar
You should be good but you should get it on a dyno to double check.
Theres plenty of dynos here in Charlotte.. i don't know how far you are from any of them
Old Jul 12, 2004 | 07:28 AM
SharpZ28's Avatar
Thanks ROOSTER93V8, I have had alot of people tell me to dyno it. I think the closest place to me that can do this is a place called Turbo Tune in Greensboro, about a three hour drive from me. My stock fuel pump just bit the dust, so maybe after I install the new one ( Walbro 255LPH In-tank ) I will look into a good dyno tune. Thanks again for the reply.
Old Jul 12, 2004 | 08:21 AM
just becareful of that place.
I don't think they are outfitted to tune your car anyways.
Old Jul 12, 2004 | 09:24 AM
SharpZ28's Avatar
Have you ever had any dealings with them? I have e-mailed them several times and have never had any replies. Do they specialize in rice burners?
Old Jul 12, 2004 | 02:00 PM
i've done quite a few DFI and chip cars that went thier first and just ended up getting charged alot of money and have a real crappy tune..
I've never delt with them one on one though
Old Jul 12, 2004 | 07:59 PM
1BadAzzGT's Avatar
I realize you can GET AWAY with running an FMU and smaller injectors, however, time/experience has show/told me that is not the way to go. Why not go to larger injectors besides $$$$???
Old Jul 12, 2004 | 08:19 PM
considering hes got a speed density car its the only choice unless he wants to run a cyclone computer.
Theres nothign wrong with a FMU, its a fuel pressure regulator
Old Jul 12, 2004 | 09:53 PM
1BadAzzGT's Avatar
Understood but in my eyes, it's a bandaid for a bigger problem. But you're right, it's a fancy fpr.
Old Jul 13, 2004 | 09:11 AM
2MCHPSI's Avatar
FMU's are ok. They are not great, but do save you the hassle of getting a custom tune... Most of the time it will take several tunes to get it right.. An FMU can keep you away from the headaches of that if running manual retard. Running 100+ pressures is kind of a risk also.. You need to make sure the fuel pump can handle higher pressures if running an FMU and smaller injectors.
Old Jul 13, 2004 | 09:37 AM
1BadAzzGT's Avatar
Come here and give me a hug you big bully. I still have a chevy manual in my garage --- wonder who owns it? LOL
Old Jul 13, 2004 | 08:26 PM
Most cars i've delt with don't hit 100psi.. I'd like for some of you FMU guys to actually put a feul pressure gauge on the car before making that assumption with calculations.
Old Jul 14, 2004 | 08:34 AM
2MCHPSI's Avatar
Assumption??? ..You are the only one assuming here, and you know what that makes you. Mine ran over 100 psi. Never said they all would.. What I meant it is possible to see that kind of pressures. Defend the FMU all you want. It is far from consistant and accurate all of the time.. Most people who spend a ton of money on their setup will actually want to pay a little extra to take that junk off their car for piece of mind.. Nothing wrong with that.
Like I said before, FMU's are just ok, nothing special..
What up Timmay! I got your number you freak. I will call you this week
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
