Injector Question
Originally posted by incarnus
I hope that one of the things included in your ported heads is larger combustion chambers, because if you're running that cam with stock compression and boost I think your cylinder pressure is gonna be kinda high.
I forget all the different cam specs, but the XE 230/236 on a 114 is a blower cam, right?
I have the MSD timing retard with the kit (adjustable from 1-3 degrees per # boost). Is that also the ignition box, so I only needa coil?
Lots of LT1s run 6# on stock compression, but that cam you have is gonna act like a blower cam and increase your cylinder pressure. Yeah, a tight LSA will allow your expensive boost to blow out the exhaust, but it will also keep your stock internals from going "kaboom." I'm afraid my knowlege in the area is far from complete, but I know it works about like that. I just wouldn't pully up if I were you.
Jul 4, 2005 05:00 PM
