im back for a couple more questions before i finish my part list
ok im trying to finish up my part list, and i was wondering. For those who dont know, heres my build specs.
LT1 350
18.6cc Dished Forged Pistons
Stock Heads Ported and Polished
Forged H-Beam Rods
Stock Crank
Stealth 3000 Stall
58mm TB
Ported Intake Manifold
Rear Mount T70 turbo(.84 a/r hotside, .70 a/r cold side)
Pacesetter LT Headers
!AC
!EGR
!AIR
Thats about it.
im wondering a few things about valvetrain parts. like whats best for my build and i wont have many problems with.
I need to know who makes a good turbo cam, ill be running about 10 psi?
Do i need special pushrods or will the regular comp cams hi tech pushrods work?
Valve Springs? what are you guys running?
Rocker Arms? 1.5rrs? 1.6rrs? What brand, and type?
Im planning on getting the ls7 lifters so that answers the lifter question. so i think thats it, ill add if i think of any other parts i may need help with. thanks guys.
LT1 350
Forged H-Beam Rods
Stock Crank
Stealth 3000 Stall
58mm TB
!AC
!EGR
!AIR
Thats about it.
LT1 350
Forged H-Beam Rods
Stock Crank
Stealth 3000 Stall
58mm TB
!AC
!EGR
!AIR
Thats about it.
I need to know who makes a good turbo cam, ill be running about 10 psi?do you want an off the shelf, or a custom? off the shelf look at the comp 218/230 or 224/236 blower cam. Both will work good. Custom, look at cammotion
Do i need special pushrods or will the regular comp cams hi tech pushrods work? com hitechs will be fine
Valve Springs? what are you guys running?what was recommended for my cam
Rocker Arms? 1.5rrs? 1.6rrs? What brand, and type?comp magnum 1.6 rr's
LT1 350
Forged H-Beam Rods
Stock Crank
Stealth 3000 Stall
58mm TB
!AC
!EGR
!AIR
Thats about it.
