hp estimate
hp estimate
i am gonna need for a fuel system. ill give you everything i know about the setup.
383 stroker block out of a 94 z
lunati forged h beams and crank
je blower pistons 8.25 compression
high volume oil pump
electric water pump
comp cam special grind 236/248 579/579 114
lt4 intake
lt4 heads bee hive springs 1.6 rr
d1sc procharger twin high flows gonna run around 20 psi hopefully
headers full loudmouth exhaust
will be getting a dana60 hopefully it is quiet hahah
full suspension
spec stage 4
any help is appreciated, or fuel systems i would like the most out of this setup and will push it hard! thanks guys
electric water pump
lt4 intake
full suspension
spec stage 4
Properly setup though, if you max out the D1SC (my guess is that you won't see over 18#'s of boost), with the setup you said, properly tuned, it should do an easy 650-700 RWHP if not more.
Also, if possible, you may want to consider going with a FAST system to properly run everything.
BTW, I dyno'd my car at 15.3#'s of boost, and it was all done with pump gas on the stock PCM. If I had the FAST system in place of the PCM, I could have run more boost, and without a doubt gained more HP, still running off of pump gas. Video of my tune here>
Call 911 I Have Watched Your Video A Few Times Before Actually, Pretty Sweet Setup. How Do Those Meth Injections Work, Do They Automatically Turn On When U Hit Higher Boost Or What. I Havent Read Much About Them.
I am sure you could rig it to come on at a certain amount of boost in the same way I have my 2nd fuel pump kick on from a HOBBS switch at 4#'s of boost.
I am by no means an expert on the details of how they turn on though since I do not run Meth inj. in my car.
Rich (rkause) would be the best one to ask for details on this. He is IMO the most knowledgable person in this forum.
