how much power can be made with stock heads
I will be runing the stock LT1 heads on my set up , ported by Ai on a 353...What kind of numbers have people made with the stockers...
Re: how much power can be made with stock heads
Sikora's 8.9_? second SC'd LT1 is running GM LT4 heads, with a good bit of work. I think the main reason he isn't running AFR's is the class he's in. Quite impressive for a factory head.
LJ, you've got the fastest stock casting LT1 head so far right?
