How much does stroking really help in FI???
so in a FI application how much does stroking the motor really help? do the extra cubes really matter that much?
Why doesn't anyone leave the bores alone to retain cylider wall thickness and let the motor last through more rebuilds?
Re: How much does stroking really help in FI???
Also, you don't need to rip into the cylinder walls to have a stroker...
My 377 runs quite well.
In a N/A deal it's a big help. With regard to centrifgual blowers, the stroke does offer abit more low speed torque before the boost comes on. For a turbo deal, I like the bigger bore w/ a 3.5" stroke. They all work pretty darn good with the right parts.
Most people buy a forged crank when building a high HP motor. Since both stock and longer stroke cranks cost about the same, why not get the stroker crank? It's basically free hp/tq, just some extra clearancing.
I realize that most people do it since they are buiying a crank anyways, but in a blown motor I was wondering if there was a reason other than "might as well since it's being bought anyways"
Originally posted by 64duece
. . .With regard to centrifgual blowers, the stroke does offer abit more low speed torque before the boost comes on. . .
Centrifugal blown cars build boost linearly with rpm, so any help on low-end is appreciated. Big converters can make up for the soft low-end also, but they aren't too streetable.
Mike
also the fact that strking the motor will add to more exhaust flow... hence less turbo lag allowing one to run a bigger turbo (of course this in only for a TURBO charged car) and on a blown car like the others said the added torque would be ideal
RUENUF
Mar 13, 2016 03:37 PM
