How much boost can my setup handle?
Old Jul 8, 2009 | 03:50 PM
  #16
Lisa33's Avatar
Originally Posted by boosted-lt1
Lisa,
Can you explain your thoughts on this? Obviously you have pressure loss through even the most efficient core and added weight/complexity - But if an IC is 70% efficient then you are taking say 0.7 X 200F = 140F out of the air before you spray.
Is 140F reduction worth a typical ~1-3psi loss? Or just run the compressor at a high efficiency and spray 'more' fuel/meth?
Thanks,
Scott.
Havent done any exact calcultions on it but (just test and tune) oure 4" FMIC and plumming were a restriction on oure car (also extra weight) and changing pullies wasnt an option since the F1 was over its limits, note i wrote E85( = 109 octan RON), É85 takes a lot of heat from the incoming air to evaporate the E85, aprox 3.5 times more energy/heat compared to gas so the combustionchamber temperatur difference isnt so big as it looks like when you compare IAT.
Agree about IC vs meth inj on a streetcar, is an easy choice if you run on gas, E85 would be another thing, If you stay araound 10-12 psi on a 9,0 comp engine there shouldnt be need for meth if you runníng E85.
Old Jul 9, 2009 | 04:06 AM
  #17
97WS6Pilot's Avatar
I've done some testing on my car with and without the intercooler. It appears to become a pretty big restriction at the higher airflow ranges. I would guess at about 500rwhp it becomes a pretty big restriction. After speaking with the guy at SDCE he said the 4 inch FMIC that everybody uses on their fbody doesn't have enough crossectional area. He recommended an up flow intercooler and said it would flow much better. If I raced alot I would ditch the intercooler altogether and up the meth.
Henson071
Dec 30, 2015 09:55 PM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
detroitmuscle
Jul 31, 2015 04:21 AM
