How can I get more boost without changing pullies on ATI?
Old Sep 8, 2003 | 01:53 PM
BAD 97 WS-6's Avatar
I have a P-1SC with 8 lb pulley. I called ATI today and they do make a 10 lb pulley which I am willing to buy, but I am in no mood to remove the head unit to swap the pulley. Are there any other ways to get more boost, if so, how much?
The reason I want more is with the head and cam I have I only see 6 lbs at the motor and I could use an extra two.
Old Sep 8, 2003 | 03:47 PM
1st and goal's Avatar
The only thing that may increase boost (other than a pulley change) is to improve the air intake tract with a solid intake tube (possibly moving the MAF to the pressurized side and going to a 4" intake tube) and a larger air filter.
Marc
Old Sep 8, 2003 | 10:26 PM
TimbrSS's Avatar
It's really not that big of a deal to swap pullies. I'd be surprised if it took you 2 hours. I'd guess about 1 from start to finish.
Jack car up
disconnect air intake, outlet
remove belt
pull head unit
swap pullies
put it all back together
Old Sep 9, 2003 | 12:17 AM
Wild1's Avatar
Nitrous?....
Old Sep 9, 2003 | 01:58 AM
LS1 Bird's Avatar
Bad 97, just pull the unit and swap the pulley..... Silly silly.
Mike M
Old Sep 10, 2003 | 05:36 AM
Brandy's Avatar
You could do 3 things: use a smaller engine, use a set of less flowing heads or use a smaller camshaft. Or you could change the pulleys and or maybe rev the engine higher.
Old Sep 10, 2003 | 07:52 PM
CJ's Avatar
CJ
Last time i did a pulley swap I didnt remove the head unit. But if you have to its only what....4 bolts.
SpeedJunkee
Jun 6, 2015 04:27 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
