Holley Pro-Jection + Procharger?
Old May 21, 2003 | 01:26 PM
racr4jc's Avatar
Anyone ever use the Holley Pro-Jection TBI in conjunction with a centrifugal supercharger in a blow-thru setup? Anyone ever use the Pro-Jection at all? Considering for use on my 383 because I like my Super Victor Intake, don't want to spend a grand getting it set up for injectors, and would like better control over a carb.
Old May 24, 2003 | 11:59 AM
Brandy's Avatar
The last Projection system I worked with did not use a MAP sensor. There is no way to boost reference the fueling. Basically they have 5 ***** to adjust the fueling: Idle, accelerator pump, main, high rpm and choke. A nice 750 double pumper has all of these adjustments and is alot cheaper They do offer a more expensive multiport system that will run in speed density mode but make no mention of boost referencing.
Old May 26, 2003 | 01:57 AM
sleepybu's Avatar
do a search hear... http://www.thirdgen.org/techbb2/foru...?s=&forumid=15
There are some guys useing that system on a boosted motor. It's a newer system that us a pc to fine tune. It uses a map sencor to.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
