Has Anybody used a MSD crank Trigger with a Procharger?
Old Jul 28, 2005 | 03:59 PM
1 DWN CAM's Avatar
I have a 92 Camaro, and I am using a ATI procharger with their TPI kit D1-SC compressor. I have a MSD Crank trigger kit on the front of the motor and I am about to install the huffer but noticed that the crank trigger has messed up the alignment of the pulleys with the huffer. Has anybody done this setup? What did you do to correct it? Do I need to make all new spacers for the charger brackets?
Old Jul 29, 2005 | 11:53 AM
Ponyhntr's Avatar
Re: Has Anybody used a MSD crank Trigger with a Procharger?
Take the spacer that ATI supplied, and remove material off of it equal to the thickness of the trigger wheel.
Old Jul 29, 2005 | 05:31 PM
1 DWN CAM's Avatar
do you have the same setup?
Old Jul 29, 2005 | 06:23 PM
Ponyhntr's Avatar
No, but I have worked with them in the past.
Old Jul 29, 2005 | 06:47 PM
1 DWN CAM's Avatar
I have not yet taken very much out of the very large box, how many spacers are we talkin about? And this should bring the alignment back into spec?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
TT350
Mar 31, 2015 07:44 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
